Mine was an easy fix, there is a non-return valve in the rear door just before it reaches the spray nozzle. It was blocked. All I had to do was remove the plastic that is just clipped on at the top of the door and replace. Unfortunately, I had spent hours tracing the fault from the water bottle. I replaced it with a streight joiner - didn't worry about the non-return valve.
Remove hose at washer nozzle, spray compressed air backwards through nozzle, reattach hose.
Spray
I need to try this today lol. When I got my car all were working, then front stopped, then headlights stopped and rear continued working. Now all of a sudden front left started working again but nothing else LOL.. Today compressed air will make a debut, considering I purchased this from Florida I was thinking maybe they used water and it froze when it got cold here in NY
I'm having an issue where the rear window washer is only dripping water from the nozzle on the wiper. My car failed its annual registration check because of it. Where is the rear window washer pump located? I've looked everywhere but just can't find it!
