Water inside
I have a 2003 Disco. Recently I have had a problem when it rains. Water will drip into the cab from both the front seatbelt holders and the top center console where the sunroof switches are. Is there a possible drain plug stopped up or what might it be? If it is a drain issue where would I possibly locate it?
If it's not the drain tubes, it's the flange seal. Either way, you'll need to drop the headliner to address the issue.
I outlined my method to fix this issue here.
https://landroverforums.com/forum/di...of-leak-62364/
sickvehicle
07-20-2011 01:18 PM
bhorwhat
01-06-2009 03:45 PM
ptelhomme
09-23-2008 09:19 PM
