water leak
Old 01-14-2009 | 06:52 PM
baddiscoII's Avatar
Default water leak
Back again, this time the truck is leaking water. I can't seem to find it, and it is not all the time. It is coming from the underneath the fron't passenger side best I can tell. I was wondering if anyone had any ideas or past problems. It will cover the frame rail and leak at the frames lowest point.But its not wet in the engine compartmet.
99 disco II 113000 miles.
Old 01-14-2009 | 07:45 PM
Default RE: water leak
Where do you live?
Are you using the A/C?
Old 01-14-2009 | 07:59 PM
baddiscoII's Avatar
No I don't use the A/C. It has antifreeze in it.
Old 01-14-2009 | 08:03 PM
Goose_Cat's Avatar
It is probably the heater core if the leak has anti-freeze in it or smells sweet in the least. If that be the case you will have to roll back the dash carrier in order to remove the heater box and replace the offending core.
Old 01-14-2009 | 08:05 PM
If it is leaking coolant inside the cabin you have a leaking heater core.
discoboy
12-20-2012 03:24 AM
Team140
08-30-2009 10:41 AM
QUINCYSDISCOVERY3
06-08-2008 07:50 PM
rgrizzard
03-06-2008 11:16 AM
