water leak
Old Jan 14, 2009 | 05:52 PM
baddiscoII's Avatar
Default water leak
Back again, this time the truck is leaking water. I can't seem to find it, and it is not all the time. It is coming from the underneath the fron't passenger side best I can tell. I was wondering if anyone had any ideas or past problems. It will cover the frame rail and leak at the frames lowest point.But its not wet in the engine compartmet.
99 disco II 113000 miles.
Old Jan 14, 2009 | 06:45 PM
Default RE: water leak
Where do you live?
Are you using the A/C?
Old Jan 14, 2009 | 06:59 PM
baddiscoII's Avatar
No I don't use the A/C. It has antifreeze in it.
Old Jan 14, 2009 | 07:03 PM
Goose_Cat's Avatar
It is probably the heater core if the leak has anti-freeze in it or smells sweet in the least. If that be the case you will have to roll back the dash carrier in order to remove the heater box and replace the offending core.
Old Jan 14, 2009 | 07:05 PM
If it is leaking coolant inside the cabin you have a leaking heater core.
discoboy
Dec 20, 2012 02:24 AM
Team140
Aug 30, 2009 09:41 AM
QUINCYSDISCOVERY3
Jun 8, 2008 06:50 PM
rgrizzard
Mar 6, 2008 10:16 AM
