Water Leak Problem
Old May 14, 2015 | 09:16 AM
dead_battery's Avatar
Originally Posted by Alphamale
Just behind the gutter corner trim just at the corner of the screen where the gutter meets the 'A' pillar inner and outer skins, roof and inner top of the side panels all the panels are meant to be sealed against water ingress, but in many cases this was missed of badly executed.
Remove the 'A' pillar trim and corner section of the gutter. examine the panels where they met in the corner of the screen and you will likely find a hole or loose filler. Clean away all the old filler you can get out and degrease the area ready for fresh sealer. I would not recommend a silicon based filler as they do not adhere for long. When I did mine I got a tube of car body sealer from my motor factor shop.
It is likely that you will also find rust in the area that you must clean and treat properly to affect a good repair. You will also find that water will have traveled down inside the 'A' pillar and could have started to rot the metal in the scuttle below the screen just where the 'A' pillar passes the fender and bonnet hinge also check for water ingress behind the fuse box and connection by passenger kick panel.
Looks like you'll need a new head lining too.
You mean something like this Alphamale? Same on passanger side too
Old May 14, 2015 | 09:17 AM
Looks like someone done a botched job on the holes
Old May 14, 2015 | 09:38 AM
drowssap's Avatar
that could do it
Old May 14, 2015 | 02:24 PM
Thanks all for your advice and help, much appreciated!
Old May 14, 2015 | 03:21 PM
zeroone's Avatar
I'm gonna suggest checking the sunroof drains and roof rack mounts regardless. Both are not just common but guaranteed. I had issues in all 3 places. it got to the point yours is at and I had the headliner refinished. The smell became atrocious.
If you know how to use Google Drive, I can give you access to a magazine article going in depth how to take care of the sunroof issue. Is so just shoot me a PM and I'll give you access. Done it for a few people.
discoboy
Dec 20, 2012 02:24 AM
Team140
Aug 30, 2009 09:41 AM
QUINCYSDISCOVERY3
Jun 8, 2008 06:50 PM
rgrizzard
Mar 6, 2008 10:16 AM
