Water LEAK question.
Old Jun 17, 2007 | 03:11 PM
TraV300's Avatar
3rd Gear
Default Water LEAK question.
I have a 2003 disco that i bought about a month ago and i drove it in the rain for the 1st time yesterday and i have multiple leaks. There is water running down the A pillar, water coming out from the seat belt opening on the B pillar and its leaking from under the dash so the carpet it wet in the front seat and back seat on the passenger side. Anyone know where these leask could be originating from ?
Travis
Old Jul 17, 2010 | 02:27 PM
smileyguyblue's Avatar
Travis
I recently bought a 2002 Disco II & have the same problem with the same type of leaks. Have you found a resolution yet? I cant seem to find any solid answers yet. Thank you!
Old Jul 19, 2010 | 01:06 AM
yloDiscoII's Avatar
There is a TSB regarding the A-Pillar leak.
But, for the types of leaks you are describing, you'll want to check your sunroof drains. You'll have to pull down the headliner to gain access. Also visually check the seals around the sunroofs and use a black silicone caulk around the edges that look suspicious.
Old Aug 4, 2010 | 01:22 PM
Thank you for your reply. It wasnt as bad as it seemed. I simply removed the nipple off of the drain tube underneath & problem solved!
discoboy
Mar 2, 2010 06:57 PM
Team140
Aug 30, 2009 09:41 AM
cantuchristoph
Jun 7, 2009 09:21 PM
QUINCYSDISCOVERY3
Jun 8, 2008 06:50 PM
rgrizzard
Mar 6, 2008 10:16 AM
