Water leaking in driver door
Old 08-10-2011, 06:27 PM
llinneman's Avatar
4th Gear
Default Water leaking in driver door
I have had water coming in my driver door. Water is coming in through the weatherstrip at the front of the door right between the mirror and the body. The weatherstrip looks ok, no cuts or damage and it is not hard or deteriorating. Any one have any suggestions?
Old 08-11-2011, 11:07 AM
llinneman's Avatar
4th Gear
Exclamation
Also, maybe the weatherstripping compresses over time, causing it to not fill the gap completely?
Old 08-11-2011, 12:31 PM
Close the door and step back and look closely. Does it seem out of line with the frame of the whole door? There is a a way adjust that. You could do a search or I'm sure someone that knows will chime in. It is very simple from the little I do remember. hinges or something like that.
rally1
02-22-2022 06:22 AM
joshp01
12-05-2021 07:50 PM
sickvehicle
07-20-2011 01:18 PM
Quick Reply: Water leaking in driver door
