water leaking into the cabin floor..
Old Aug 17, 2019 | 04:08 PM
botija69's Avatar
5th Gear
Unhappy water leaking into the cabin floor..
Hey guys!! my fellow land rover lovers, my D2 is leaking water on to the floor mats in front. Could that be condensation from the A/C, or low on free on??? does anyone of you have an idea?.. I love you all
Robinson
Old Aug 17, 2019 | 04:11 PM
Dave03S's Avatar
Probably AC drains plugged...
How long has it been since you squeezed your nipples?
It's a regular maintenance item with these.
Old Aug 17, 2019 | 04:24 PM
botija69's Avatar
5th Gear
Talking
I don't mean to be a pest, but I thought that i Knew everything about my D2, But do you know where they are located, or if you have a picture I will really appreciated.
thank You Dave03S]
Old Aug 17, 2019 | 04:33 PM
Dave03S's Avatar
Underneath the truck look for the area where the front drive shaft comes out of the transfer case, then look up to the bottom of the floor for one black rubber nipple on each side of the sloped area that actually is the underside of the center hump between the seats. Roughly underneath the cup holders.
The hole in the center gets clogged. Squeeze them to clear them but watch out, they will be full of old musty water that you don't want a face full of. If they seem really clogged you can stick a small like 6/32" rod into the hole to clear it out further. #10 wire would also work.
Some people remove them entirely. They are there to keep debris from splashing up into the drain tube.
They are what cause the two small puddles under the center of your truck when you park after driving with the AC on.
Old Aug 17, 2019 | 04:42 PM
SundayFunday's Avatar
A real common issue with water in cabin, particularly on floor boards, are the sunroof drains. (Top Windshield seem deserves a check too)
you have sunroof’s? - they clog and weep onto headliner. Front tends to drain down A pillar - rear can drain down B pillar. Will hold moisture under your carpets and rot the floor boards
Rovermike85
Feb 5, 2013 07:01 PM
mdwman
May 13, 2010 08:25 AM
knac1234
Jul 25, 2009 09:56 AM
ucfmethod
Jul 21, 2008 08:42 PM
QUINCYSDISCOVERY3
Jun 8, 2008 06:50 PM
