water pooling under hood
Old Jan 21, 2010 | 12:57 PM
NiteTrain's Avatar
Default water pooling under hood
I've got water pooling in the engine bay directly under the hood hinges in that channel. I don't see a drain and this cant be good theres a ground wire in there.
any suggestions? I'm going to wet vac it out after the rain stops but need to fix problem so it wont happen again.
Old Jan 21, 2010 | 01:57 PM
yloDiscoII's Avatar
The drains are there, just in a weird, hard to see place. Use a coat hanger or something similar to snake it out. The water will drain to the ground in front of the doors. I just so happen to have a picture of said drain
This is the driver's side....
Old Jan 21, 2010 | 02:41 PM
NiteTrain's Avatar
thanks for posting the pic ylo. I see my problem now, my drains aren't clogged. I usually back into my steep up hill driveway but the other day I pulled in front first. Since the drains are to the front of that trough it was unable to drain.
Alex_M
Sep 7, 2024 05:21 PM
steveo2000
Sep 8, 2015 08:00 AM
Retroman1969
Apr 6, 2014 09:05 PM
drhunter
Apr 19, 2007 11:13 AM
rebooTT
Nov 13, 2006 10:04 PM
