Water Pump brand All Makes(England) or Deutche Parts(German)
I'm replacing the crankshaft seal and have the viscus fan removed in my heated garage this week. With 95,000 miles on my 2003 I found a few small drips of coolant hanging off of my oil cooler lines. When I get in there closer I will see if its coming from the water pump. Hopefully it will be clearer with whitish trail of dried coolant.
Does anyone have an opinon on either of these water pumps. Which is better/same. I have heard All Makes 4x4 is decent OEM quality. The Deuthe parts one looks good too. I dont really car about the prices.
LAND ROVER WATER PUMP 1994-2004 RANGE ROVER DISCOVERY
Fits
iscovery 2003
LAND ROVER WATER PUMP ASSY DISCOVERY DEFENDER RANGE
Fits
iscovery 2003
Your leak may be from the front cover gasket also. I would try to get an OEM pump from will tillery or pt schram as they are one part that in my experience last a long time (128k miles). I have heard bad things about the proline pump not sure about the ones you mentioned though.
My truck came with a water pump from Napa...it crapped out less than a 100 miles after it was installed by the dealer I bought the truck from.
I bought my replacement from Will, it's been good to go ever since.
Hello All
Im new to the site and need some help asap!!!!
I have a 2003 Range Rover big body and badly need to replace the water pump. Can someone help me with some instructions on how to replace it... Also i found one one the web for $200, would that be about the right price for the OEM replacement.
Thanks much
desperate
Thanks much
desperate
aj this is the one you want,
Land Rover Water Pump Fits Discovery, Range Rover & Defender Vehicles
not 100% sure it will fit an 03 RR though, it fits:
Discovery I | '94 - '99
Discovery Series II | '99 - '04
Range Rover Classic | '95 | For Vehicles with serpentine belt
Range Rover 4.0 (P38) | '95 - '02
Range Rover 4.6 (P38) | '95 - '02
Defender 90 | '97
Defender 90 | '97
