Water pump gasket
Old Dec 31, 2010 | 11:35 PM
willrok13's Avatar
Exclamation Water pump gasket
Does anyone know of any tricks to help remove the water pump gasket? I have tried AutoZone's gasket removal foam but it hasn't touched it. As far as I know its the original gasket. Any help is appreciated...
Old Dec 31, 2010 | 11:43 PM
buick215's Avatar
You can try using a putty knife or a box cutter.
Old Jan 1, 2011 | 01:20 AM
willrok13's Avatar
Thanks for the reply. That is probably my last resort. I was just curious to find out if any one actually had any luck following the rave "plastic scraper" instructions. I have been through three plastic scrapers and I have 3/4 of the gasket left...
Old Jan 1, 2011 | 01:33 AM
buick215's Avatar
Plastic scrapers are junk. If you apply to much pressure they either bend or snap in half. The blades are not sharp enough and become even duller after light use. Use a metal one with care and you will be alright.
Old Jan 1, 2011 | 06:51 AM
lipadj46's Avatar
you will never get it off with a plastic scraper. Use a razor blade with care as it is easy to shave off the aluminum.
Old Jan 1, 2011 | 09:33 AM
You can also use a emery cloth.
Old Jan 1, 2011 | 10:01 AM
frankieoboy's Avatar
Just did that job. Took me 90 min of patience. I used a combination of metal scraper and glass scraper.
Old Jan 1, 2011 | 12:22 PM
willrok13's Avatar
Thanks for the help. I just picked up some emery cloth and razor blades. Its a rainy day here in Alabama, perfect for taking my time to work on removing the gasket in the garage!
Old Jan 1, 2011 | 03:44 PM
sideburns's Avatar
Use a new square razor blade and take your time.
outdoor7or24
Dec 22, 2014 09:31 PM
myall200
Nov 23, 2008 10:39 PM
Fonzie
Nov 10, 2007 09:29 PM
wellerdoug
May 12, 2005 05:22 PM
