Water pump gasket
Does anyone know of any tricks to help remove the water pump gasket? I have tried AutoZone's gasket removal foam but it hasn't touched it. As far as I know its the original gasket. Any help is appreciated...
Thanks for the reply. That is probably my last resort. I was just curious to find out if any one actually had any luck following the rave "plastic scraper" instructions. I have been through three plastic scrapers and I have 3/4 of the gasket left...
Plastic scrapers are junk. If you apply to much pressure they either bend or snap in half. The blades are not sharp enough and become even duller after light use. Use a metal one with care and you will be alright.
outdoor7or24
Dec 22, 2014 09:31 PM
Marni
Jun 22, 2013 05:04 PM
