Water Pump Pulley and Fan Wobbly HELP!
Hi guys! I need some help. You all have helped me before and I hope to repay the favor some day. I have a 96 discovery with 106K and the radiator fan and water pump pully started wobbling on me the other day I could hear it out of balance(you can see it out of balance when running.) Tonight it got a lot worse some type of fluid came out of the pully area and sprayed all over the block and steamed. I dont think it was anitifreeze. I shut down with in seconds and pulled her home.I am wondering if the viscous clutch is out of the water pump gave out? No signs of overheating before or durring this event. I have only ownedmy disco1 year so Im not sure what parts are originial? Thanks guys!- Alex
on
RE: Water Pump Pulley and Fan Wobbly HELP!
If both are original, replace both the water pump and the fan clutch. Make you check the radiator to make sure there is no damage done to it.
Will you be doing the work or do you have a mechanic? Make sure to shop the web for prices for both parts, also replace the belts, the t/stat and hoses if needed.
