Water-ready
Water-ready
I was looking at a snorkel on AtlanticBritish.com today and noticed that the site mentioned this would NOT allow US Discoverys to drive in water above hub-level due to the electronics.
What must be done to the Discovery I in order to make it more ready for fording water? And once prepared, how deep can one drive?
on
RE: Water-ready
One of the most important things to water proof in a D1 is the ECU whish is mounted on the passenger side of the firewall. Then you should water proof all your electrical connections, extend all breather hoses for the tranny, t/case, both diffs, check and repair all door seals and firewall plugs.
Just remember Rovers aren't totally water proof and some damage can be done.
Under the most extreme water crossing, watch the direction of the water flow, maintain a constanat speed and make sure there is someone with you incase you need a pull.
Mike
Mike
YARRover
06-07-2014 08:49 AM
ellebarto
Sights N Sounds
05-21-2013 09:35 AM
Team140
08-30-2009 09:41 AM
