Waterpump Removal
Old Mar 12, 2018 | 07:14 AM
redrover75's Avatar
Default Waterpump Removal
Can I remove a waterpump with out removing the fan?
Fan is stuck on and i am planning on replacing all the parts anyway.
Thanks,
Old Mar 12, 2018 | 08:07 AM
Sixpack577's Avatar
Yes, but you'll need a new pulley if you can't get the fan off.
Old Mar 12, 2018 | 08:28 AM
It can be a bit of a pain but I have done it before. Like he said you will need a pulley to replace the one or cut it apart to get the pulley once it's out.
Old Mar 12, 2018 | 05:32 PM
Big Jim Swade's Avatar
Have you tried getting the fan off by hitting the fan wrench with a hammer (in the right direction of course).
Old Mar 13, 2018 | 05:37 AM
redrover75's Avatar
Default Hammer
I have been hitting with BP blaster and a hammer. Maybe it will work lose by he weekend.
Old Mar 13, 2018 | 08:24 AM
LR03NJ's Avatar
Is the belt still on? I think the belt should be on and hit the wrench with the mallet towards the left. It will be hard to remove the bolts.
Old Mar 13, 2018 | 09:38 AM
OverRover's Avatar
Just buy, or rent a Fan Clutch Tool from Autozone to hold the water pump pulley in place.
And like magic the fan clutch comes off with very little effort. A Schley 61600 has always worked for me.
Old Mar 13, 2018 | 01:58 PM
redrover75's Avatar
Default Wrench
The tool that Pep Boyz rents does not get good purchase. I will try the Autozone one or Advanced one this weekend. See if i get any luck.
I got the fan off the last Rover surprisingly easy, maybe i was just not ready for it. Need a bigger wrench i suppose.
Old Mar 13, 2018 | 02:33 PM
OverRover's Avatar
A good 36MM Wrench, and proper support of the water pump pulley and you are quickly back to Happy Town!
If you can't get a "Rent-A-Tool"...NO B$, the Schley tool is well worth buying...you will use it often and it makes this repair painless. Good Luck!
Old Mar 14, 2018 | 05:10 AM
redrover75's Avatar
Default It worked
After the BP plaster it came off surprisingly easily. ordered pump and some other parts from Lucky8, preventative maintenance. I want to make this rover bullet proof. It runs about 185 degrees, lower than any other rover I have had. The cooling system will be mostly brand new when I am done.
Desert Roadrunner
Jun 24, 2010 03:09 PM
LRScott
Apr 26, 2010 08:13 PM
unstable
May 28, 2009 10:25 AM
garrett4pm
Freelander
Jan 24, 2008 11:43 PM
skydivdav
Mar 7, 2005 12:36 PM
