Weird Croaking noise
Old Apr 26, 2015 | 09:31 PM
jrock51's Avatar
Default Weird Croaking noise
Hey guys just recently bought my first discovery DII 03. Frigggggen love the car. I have been trouble shooting the little things using this forum etc.. but i've finally had a need to post. I have this weird croaking rattly noise at idle. I'm no mechanic, but I'd like to know if its something easy I can handle or do I need to take to the mechanic?
View My Video
Its not that loud, but listen for a croak/rattle. The car runs and drives fine other wise. So idk...
Edit: fixed the video link. Should work now
Old Apr 27, 2015 | 06:21 AM
dusty1's Avatar
Can't get video
Sai pump?
Old Apr 27, 2015 | 07:54 AM
jrock51's Avatar
Originally Posted by dusty1
Can't get video
Sai pump?
Thanks for the quick follow up . My SAI pump is loud at cold startups do a minute or so. You think it's related? I did have a fault code P0455. I changed the gas cap and cleared it. I haven't had the service light come on In a week or so. I appreciate the help
Old Apr 27, 2015 | 08:35 AM
Externet's Avatar
Get under the car belly up when idling and check if it comes from heat shields missing nuts on top of catalytic converters/mufflers. Watch your nose, could get toasty.
Old Apr 27, 2015 | 08:40 AM
OffroadFrance's Avatar
View My Video
Its not that loud, but listen for a croak.
A frog ...................... or maybe the person you have recently run down not quite 'croaked' yet sorry, couldn't resist.
Old Apr 27, 2015 | 05:44 PM
jrock51's Avatar
Ok will see if i can find anything. Good thing I have a 2" lift. I was on rave, and I just want to make sure where catalytic converter is. The noise is definitely from the front, and I think its passenger side more. Does that help ID the croaking?
Old May 15, 2015 | 10:08 PM
jrock51's Avatar
Default Update
Just an update. It turns out the shaft holding the water pump was causing the rattle. It had broken off and was barely hanging on. I had to replace the entire water pump. In addition, the grinding I heard at ignition was not the solenoid and/or flywheel. It was the water pump as well. 2 birds with one stone!
redbaron586
Nov 16, 2008 10:06 PM
tonyp71
Jan 13, 2008 08:46 AM
newBrover
Oct 16, 2007 05:57 PM
johnnybob06
May 29, 2007 08:52 AM
msbont
Sep 10, 2006 03:53 PM
