weird electrical issues
Old Jan 14, 2009 | 08:33 PM
doerhoff013's Avatar
5th Gear
Default weird electrical issues
hi all, newbie here! my 98 disco 1 alarm goes off every now and again for no good reason i can tell, tonight after an alarm i noticed the cooling fan cutting on and off only seconds at a time(could not make it do it on my own) and the green trailer light on the dash was very dim but flashing with no beat(ignition off). any ideas?
Old Jan 14, 2009 | 08:46 PM
Default RE: weird electrical issues
I have no idea.
Old Jan 14, 2009 | 08:53 PM
Disco Dave's Avatar
is it maybe a low battery??
Old Jan 14, 2009 | 09:00 PM
http://homepage.ntlworld.com/stage1v...icalSpider.htm
http://forums.lr4x4.com/index.php?showtopic=86
Read through these and see if maybe your problem is listed.
I too was thinking maybe a bad battery.
Old Jan 14, 2009 | 09:01 PM
Rover Rob's Avatar
Does your alarm have interior motion detection ? My 99 D2 has it and if you leave the windows or sunroof open even a crack, The wind will set it off. They can be extremely sensitive.
Old Jan 14, 2009 | 09:03 PM
Disco Dave's Avatar
are the lights dim at all, or is it hard to start? check all of your connections for corrosion and such. always good to get the basic stuff out of the way in a diagnosis.
Old Jan 14, 2009 | 09:34 PM
5th Gear
no issues with the battery, lights are bright and no trouble starting.but ill check it anyways.
no, i dont believe it has the motion detection, my 99 does and it will set off that alarm
the 2 links left discribe a starting or running problem which i dont have but good to know,
thanks
Old Jan 14, 2009 | 11:47 PM
pilsner's Avatar
check the ground wire on alarm. it is prolly lose/corroded.
Old Jan 15, 2009 | 12:09 AM
sloppyjoe's Avatar
at first thought i am thinking low or bad battery
thehun
Jun 7, 2012 12:38 PM
smoker
Mar 8, 2012 07:23 AM
rphotographer
Mar 21, 2011 09:37 AM
c_sautter
Jan 9, 2011 03:29 PM
djkiddanger
Apr 8, 2008 05:21 PM
