Weird knocking from the rear after high speeds
Old Dec 18, 2019 | 09:33 PM
Sundevil's Avatar
Default Weird knocking from the rear after high speeds
I need help. My car is making the weirdest noise from the back. It only comes after I have been driving on the freeway and come to an exit. After I completely stop about 3-5 seconds later I get a weird knocking noise that sounds like it is coming from the rear of the car. It last for 10-15 seconds then goes away. The car drives fine and only does it after the freeway. I can not replicate it unless on the freeway and stoping. In the last month or 2 I have replaced the motor mounts, transmission mounts, front drive shaft, and power steering pump and return hose. The car seemed to be driving find, but starting Monday of this week I get the noise in the morning when going to work and exiting the freeway. Does anyone have any idea what could be making this noise?? Could it be a fuel pump issue?
Any help is appreciated.
Thanks
Old Dec 19, 2019 | 05:57 AM
Jason Feuerstein's Avatar
Thanks
Start with the stuff you can see. Check that your exhaust isn't loose, the rotoflex joint, and any play in the front or rear drive shafts. If you can stand outside the car while someone revs the engine and then stops, I would do that. From your description, it seems like there's something that doesnt like the transition from high to low RPM. I wouldn't trust your hearing on this one while you're sitting in the drivers seat; sound has a tendency to travel through the body of the vehicle in odd ways.
gribur
Mar 15, 2014 11:01 PM
marv02
Nov 15, 2011 08:15 PM
pierrejchan
Nov 11, 2008 11:27 PM
wess98range
Jul 3, 2008 05:31 PM
linfieldbrah
Apr 11, 2005 03:39 AM
