whiring noise OH $#%$^%
Old Mar 13, 2014 | 05:40 PM
gribur's Avatar
Default whiring noise OH $#%$^%
ok, hope I got your attention, need help. I was driving today all was fine, then the noise started, a whirring, almost winding down noise, like the toy car you repeatedly push to build momentum right before you let em go and they race away. It only happens when going above around 30 mph and only when coasting/deceleration, brake or accelerator makes it go away. It seems to be coming from right side of car, passenger side in Canada. I could swear it was from in my glove box. I really want to nip this in the bub, please help me out.
Old Mar 13, 2014 | 05:54 PM
schwaggy's Avatar
Secondary Air Pump - No idea why it's activating when it is for you, though.
It's probably clogged with its own filter.
Old Mar 13, 2014 | 06:05 PM
gribur's Avatar
Default pump
it does not sound like the pump that kicks on when I start the car sometimes, its just a grindy whiring winding down noise, only when letting off gas or brake and decelerating, wow this is brutal trying to explain a noise and conditions lol, I really want it solved so I will do what I can to describe it.
Old Mar 13, 2014 | 06:23 PM
zeroone's Avatar
Video it. You think it is loud enough for your phone to pick it up?
Old Mar 13, 2014 | 06:28 PM
gribur's Avatar
Default video
It may be loud enough, it just started out of the blue this afternoon, just went to do some running around. It is definitely above 30mph and when I decelerate, gas or brake make it stop. I am lost lol
Old Mar 13, 2014 | 07:24 PM
gribur's Avatar
Default sound clip
Old Mar 13, 2014 | 08:52 PM
jfall's Avatar
OK so when you decelerate that creates a torque.
This is a low frequency noise and grinding.
My vote is the drive shaft is rubbing against something
or the center bearing is going bad.
or the diff is going bad.
Check your engine mounts.
Check your transmission mounts.
Old Mar 15, 2014 | 10:39 PM
FreeRideSLR's Avatar
Pretty sure it's the diff going bad. Mine started sounding like that and exploded shortly after.
Old Mar 15, 2014 | 11:01 PM
gribur's Avatar
Bought fresh fluids today, going to change everything and hopefully it stops.
QUOTE=FreeRideSLR;453031]Pretty sure it's the diff going bad. Mine started sounding like that and exploded shortly after.[/QUOTE]
david4ducati
Mar 1, 2015 07:59 PM
30more
May 28, 2012 05:01 PM
adrianwood
Freelander
Jun 13, 2005 08:53 PM
