Weird noise and cool way to test the MAF
Old Sep 4, 2022 | 10:39 AM
pathologypete's Avatar
Default Weird noise and cool way to test the MAF
Hey everyone. I have a question for you. I hear this whirring sound when the engine is running. It's a 2004 D2. It's my second D2 and I never heard this sound with my other beast. Anyone know what it is? Video attached, excuse the background wind.
Also, someone advised me as to a trick to check the MAF. Start the engine, unplug the sensor. If the car dies, the MAF is good. If the car keeps running the sensor is toast. Looks like I need a new sensor. Anyone tried this before and can vouch for its accuracy?
Thanks. I am head for some dirt....
Pete
File Type: mov
Old Sep 6, 2022 | 06:29 PM
XRAD's Avatar
could be many things..hard to tell in the hurricane
worn idler pulley
Air leak
cam or crank bearings
worn rocker arms
power steering pump
trans pump
water pump
or pretty much anything else that turns
Old Sep 7, 2022 | 02:19 PM
nashvegas's Avatar
Sounds to me like one of your two idler pulleys or a belt driven accessory.
I literally just replaced the smaller (70mm?) idler pulley on the pass side of one of my D2's yesterday... mine sounded kind of similar.
Best way to test... remove the belt. Spin everything by hand. In my case, the one idler pulley made a whirr noise when I spun it by hand, replaced it, and now silence.
Old Sep 7, 2022 | 06:11 PM
Extinct's Avatar
Can confirm the MAF test works.
Old Sep 12, 2022 | 05:36 PM
Thanks! I know, the wind was pretty bad!
Old Sep 12, 2022 | 05:38 PM
That's a great idea. I will check the pulleys. Thanks!!
Thealooox
Jun 21, 2022 12:02 PM
mr. choodles
Jul 8, 2018 01:37 AM
Alkalinecat
Aug 27, 2013 08:30 PM
nickm347
Apr 20, 2011 08:11 PM
ezikial4
Jun 28, 2009 08:26 PM
