Weird rear brake light issue
Old Mar 7, 2019 | 10:13 PM
04in719's Avatar
Default Weird rear brake light issue
So my passenger side rear brake light works fine when the parking lights are off. When the parking lights are on the brake light on that side goes off when the brake is applied.
It's not the bulb, I switched from side to side. I swapped the whole light assembly from side to side, same thing.
Any ideas on what could be the issue?
Thanks in advance as always.
Old Mar 7, 2019 | 11:42 PM
shanechevelle's Avatar
Have you checked all the bulbs? Sometimes a wrong bulb somewhere else causes a short.
Old Mar 8, 2019 | 12:00 AM
No Doubt's Avatar
Open the vented black panel in the right rear corner column in the back hatch area of your Disco 2. Inside that access area will be a roughly square electronic part that is supposed to be held onto the frame by a center grounding screw.
Clean and tighten that screw+grounding post.
The above solved all sorts of weird brake light issues for me. Maybe it will help you, as well.
Old Mar 8, 2019 | 12:11 PM
04in719's Avatar
2 great suggestions, I'll give them a go this weekend.
Thanks much!
coors
Dec 3, 2015 08:28 PM
keithlarue
Dec 5, 2013 06:43 AM
rreinholt
Oct 10, 2013 08:47 AM
jbarr89
Aug 7, 2012 08:38 AM
modernhomesteader
Jul 22, 2011 12:15 PM
