Weird sound coming to a stop
Old May 11, 2022 | 11:10 AM
Brandon318's Avatar
Default Weird sound coming to a stop
Hey hey! Wanted to run this by you guys to see if you've experienced something similar:
On the 2002, when coming to a stop, not all the time, but most of the time lately, there's a rumbling noise that's audible when the stereo is off. Not super loud. It's the same sound that you here when a lifted pickup drives by with mudding tires. That low drone. It sounded like its coming from the back, but hard to know for sure. I popped the back wheels off yesterday to do a quick visual and everything looks good. Pads are great, rotors are great. Ideas? I guess I could start to consider the hub?
Old May 11, 2022 | 11:26 AM
Richard Gallant's Avatar
Rotoflex ?
Old May 11, 2022 | 11:32 AM
Brandon318's Avatar
Originally Posted by Richard Gallant
Rotoflex ?
Only a few years old, still looks new.
Old May 11, 2022 | 01:20 PM
cvhyatt's Avatar
Maybe its time to put that mega torque wrench to use and replace the hubs again!
Old May 11, 2022 | 01:28 PM
Brandon318's Avatar
I thought by buying it that might mean I’d never use it 😅
Old May 11, 2022 | 02:08 PM
Harvlr's Avatar
I would have thought that bad hub bearings would be noisy at speed especially when cornering, not at a near standstill.
Old May 11, 2022 | 04:56 PM
Extinct's Avatar
Exactly, just replaced my right front due to that exact reason. Interestingly it made more noise turning right then turning left not what I expected. I would make another pass around and look at all of the pads even the interior ones, usually a low growl when stopping is indicative no pad material left and metal of metal on the rotor
Old May 12, 2022 | 05:16 PM
Externet's Avatar
My opinion will surprise many.
Something in the computer or climate computer senses the vehicle speed decreasing to about 4MPH and a servo closes (or opens) a ventilation flow gate by the passenger feet area. It also sounds the same in reverse (restoring) the ventilation gate position when accelerating from a stop up to 4MPH if the engine is quiet enough.
Exposed the behavior previously on some post but seems nobody hears it. I suspect the climate system exterior air intake (or recirculation) changes when moving and when stopped by some esoteric minuscule design reason.
Some day I will try to come to a stop quietly with engine (key) off to compare if the noise persists, or start downhill with engine off to confirm the same noise reversal.
Brandon : try a small kid as helper, head stuck under the glove box and paying attention to the noise source area while reaching a stop. And come back with findings !
evan.byron@gmail.com
Aug 2, 2021 01:22 AM
Gaz2510
Jul 25, 2021 11:43 PM
FLA Rover
Sep 13, 2013 11:10 AM
blcp86
Aug 29, 2009 01:22 PM
llPANCHOll
Jan 29, 2009 09:11 AM
