Welded spider gears?
Old 07-12-2015 | 04:45 PM
Alex_M's Avatar
Default Welded spider gears?
Has anybody done it on theirs? To what effect? I know the factory spider gears are pretty weak, I don't know if/how well it would work on a D2. Did you do front or rear? Did you end up snapping an axle at any point because of it? How was your on road handling changed?
Thanks guys!
Old 07-13-2015 | 06:06 AM
antichrist's Avatar
If you weld the front it's going to be really hard to steer.
Old 07-13-2015 | 06:56 AM
Alex_M's Avatar
Thats pretty much what I was figuring. I don't think rear should cause too much trouble though.
Old 07-13-2015 | 07:58 AM
Depending on the type of wheeling you do, welding your 2 spider gears still give you a weak diff compared to using a 3 spider diff.
Old 07-13-2015 | 08:39 AM
ZGPhoto's Avatar
Better off using a detroit... Rover diff is indeed pretty weak
Old 07-13-2015 | 09:55 AM
Alex_M's Avatar
I mostly do light wheeling and driving on the road. I don't really have the cash for new diffs, but when I do in the future I'll be doing an LSD in the front, locker in the rear, and gears. Right now I'm just looking for a cheap improvement over what I've got.
Old 07-14-2015 | 07:05 AM
antichrist's Avatar
If you do a lot of on-road driving a welded spider will cause quicker wear of your rear tires.
I don't know which Rover diff has 3 spider gears. I'm not sure how that would even work.
Old 07-14-2015 | 07:21 AM
fishEH's Avatar
Fix your traction control.
Old 07-14-2015 | 04:23 PM
Alex_M's Avatar
Any idea how much it would increase wear? I mean, 15-20% is one thing, but 50% would be too much.
Old 07-14-2015 | 04:46 PM
antichrist's Avatar
Most references to welded diffs and tire wear seem to be on drifting forums, but here's one a 4WD forum pros and cons of running welded diff on a dd
My impression is that the majority of 4WD people who weld them do it on rigs that are mostly, if not 100%, off-road.
Quick Reply: Welded spider gears?
