Welding on Discovery 2 Frame
Old Sep 10, 2014 | 12:05 PM
powair's Avatar
Default Welding on Discovery 2 Frame
Does anyone know if the vehicle ECU needs to be removed before welding on the frame. I am planning on having the Door frame A-pillar post welded back on as its popping every time I open the door.
If you don't have to remove the ECU then is disconnecting the battery sufficient.
Old Sep 10, 2014 | 12:16 PM
ZGPhoto's Avatar
not required
Old Sep 11, 2014 | 12:17 AM
bosshogt's Avatar
I built my entire steel bumper and attached the grounding clamp daily. It will be fine. 10 weeks on and off of welding and no issues. Current flows to the grounding strap...shortest path to ground. Look at muffler shops they are welding all the time on cars and do not dissconnect the battery or ECU.
Old Sep 11, 2014 | 07:01 AM
Richard Moss's Avatar
If you feel uncomfortable about it, disconnect the earth lead (ground lead) from the battery.
Old Sep 11, 2014 | 09:21 AM
dusty1's Avatar
I have a quick disconnect on my batteries....never bothered with the simple turn of the **** for welding........and I have all kinds of junk welded on there.
more important is that if you are putting trick tabs or something that will see a lot of pressure and demand.......plate it on that section. the frame is thin
Old Sep 11, 2014 | 09:59 AM
ZGPhoto's Avatar
yes, ALWAYS PLATE THE FRAME!
a dude I know had his rear panhard mount pull a hole out of his chassis, rust free, under some serious force.
cogsley
Aug 13, 2014 03:24 PM
devildog01
Mar 2, 2010 06:33 AM
03discoman
Jan 22, 2010 11:03 PM
NiteTrain
Off Topic
Aug 20, 2009 05:48 PM
jgbufton
Nov 17, 2007 10:04 AM
