Well, this was fun...
Old Feb 20, 2020 | 02:23 PM
deodra's Avatar
Default Well, this was fun...
Look what happened! Totally sucked-- at least it was two miles from home
The output flange has some play, too. Looks like I will be replacing the output shaft bearing and a front drive shaft, too. I may as well do the rear bearing and rotoflex while I'm at it. I still have an oil leak that I can't quite pinpoint yet. It's driving me crazy!
Totally fried front drive shaft
Old Feb 20, 2020 | 02:37 PM
boston4's Avatar
Yikes! That doesn't look like a stock driveshaft, either. Lucky that it stayed in one piece.
Old Feb 20, 2020 | 03:49 PM
Richard Gallant's Avatar
Lucky guy it just went like that
Old Feb 20, 2020 | 07:20 PM
Red5's Avatar
Go buy a Powerball. Your stars are clearly aligned.
Old Feb 21, 2020 | 02:01 AM
JUKE179r's Avatar
Good catch!
Old Feb 21, 2020 | 07:18 AM
deodra's Avatar
It's definitely not. It looked darn near new when I purchased it. It also has a "2013" stamped on it. I wonder if the play in the output side of the transfer case caused it to prematurely go belly up?
Old Feb 21, 2020 | 08:01 AM
Alex_M's Avatar
I've never seen one that didn't have some play in the output of the transfer case.
Old Feb 21, 2020 | 12:34 PM
deodra's Avatar
That's what I've heard, too. It's not an amazing amount, but it is annoying. One can wiggle it a little in different directions. I'd expect some rotational play due to gears instead of chains on the inside, but I'd not think you should be able to wiggle it. I would think that would cause vibration and maybe cause a shaft to die prematurely. Maybe I'm wrong?
Old Feb 21, 2020 | 01:07 PM
@deodra I think the biggest issue on these is the centering ball, if that binds you would get a failure in that double joint. And it is not something easy to grease
Old Feb 21, 2020 | 01:14 PM
deodra's Avatar
Very good point! From all accounts, I've come to realize that if I start to feel a vibration, time to replace. LOL! I don't feel up to replacing a tranny.
