Welp....
Old Jun 23, 2019 | 06:51 PM
Discorama's Avatar
My ticking appears after longer HWY driving when oil temps reach 240F (measured and the sandwich plate). Then the ticking is still persistent the next day after moderate warm up already. 24 hours later the ticking is gone and that feels like it is self healing. Also topping up fresh oil helps to get the ticking away (I have to add one quart every 600 miles anyway). I wonder if adding an oil cooler will fix the problem. Or does the tick happen with older D2s too, which have an oil cooler?
Old Jun 23, 2019 | 07:49 PM
Mullins.cody's Avatar
Think Im going to try and use my friends garage when I get back from my month of leave. Going to try all of your suggestions if that doesn't work. Will probably look into dropping oil pan see if anything is loose or removing front cover to see off oil pump is bad.
Old Jun 23, 2019 | 10:38 PM
Ben Matheson's Avatar
Sound the same with the belt off?
garywwood
LR4
Aug 12, 2020 08:32 AM
dasherman
Jun 1, 2018 08:05 PM
KernowDiscovery
May 30, 2014 10:44 PM
Bob Loblaw
Apr 12, 2014 04:49 PM
pickps
May 14, 2007 12:42 PM
