What is the blank switch located to the right of the mirror switch
Old Dec 11, 2017 | 08:52 PM
09dewaed's Avatar
Default What is the blank switch located to the right of the mirror switch
what option is designed for this location?
Old Dec 11, 2017 | 09:33 PM
Friday Night Disco's Avatar
Air ride self leveling
Old Dec 12, 2017 | 06:47 AM
mollusc's Avatar
Nope. Air ride height is in the main cluster on the right side of the steering column.
Pretty sure that I remember reading in the RAVE that that's where the headlight levelling/aiming controls go, if fitted.
Old Dec 12, 2017 | 07:44 AM
You are correct, I apologize for the bad info
INTERIOR TRIM COMPONENTS
76-3-14 REPAIRS
Panel - auxiliary switch
$% 76.46.38
Remove
1. Carefully remove electric exterior mirror switch
from auxiliary switch panel and disconnect
multiplug.
2. Models with headlamp levelling: Release
**** and remove nut securing headlamp
levelling switch to auxiliary switch panel.
3. Release 2 fasteners and open fascia access
panel.
4. Models with headlamp levelling: Remove
headlamp levelling switch from auxiliary switch
panel and disconnect multiplug.
5. Models with A/C: Remove 2 screws securing
in-car temperature sensor to auxiliary switch
panel.
6. Models with A/C: Disconnect multiplug from
in-car temperature sensor and remove from
7. Release 2 clips securing auxiliary switch panel
to fascia and remove panel.
Refit
1. Position auxiliary switch panel to fascia and clip
into position.
2. Models with A/C: Connect multiplug to in-car
temperature sensor.
3. Models with A/C: Position in-car temperature
sensor to auxiliary switch panel and secure with
screws.
4. Models with headlamp levelling: Position
headlamp levelling switch to auxiliary switch
panel and secure with nut.
5. Models with headlamp levelling: Replace
cap and connect multiplug to headlamp
levelling switch.
6. Connect multiplug to exterior mirror switch and
fit switch to auxiliary switch panel
Old Dec 12, 2017 | 08:02 AM
OverRover's Avatar
Yep, mollusc is right.
Old Dec 12, 2017 | 08:13 AM
mollusc's Avatar
Yep. Another situation where just looking in the book will get you the answer...
Old Dec 12, 2017 | 08:53 AM
Sandman614's Avatar
Which book, I picked up a Novel off my wifes shelf and it was less than helpful
Old Dec 12, 2017 | 09:12 AM
wjsj69's Avatar
Did not know that was available; seems like a very cool option! Built in to the face-lift lights I'm assuming?
Old Dec 12, 2017 | 09:20 AM
Alex_M's Avatar
If it's a facelift thing it's not standard. My 03 didn't have anything there. I used the spot to add a voltage gauge.
Sure would be nice to have with as much as I tow, though.
Old Dec 12, 2017 | 10:18 AM
mollusc's Avatar
I believe it's a Euro-spec thing. Like the automatic folding mirrors that were Japan-only.
