What is the blank switch located to the right of the mirror switch
Nope. Air ride height is in the main cluster on the right side of the steering column.
Pretty sure that I remember reading in the RAVE that that's where the headlight levelling/aiming controls go, if fitted.
INTERIOR TRIM COMPONENTS
76-3-14 REPAIRS
Panel - auxiliary switch
$% 76.46.38
Remove
1. Carefully remove electric exterior mirror switch
from auxiliary switch panel and disconnect
multiplug.
2. Models with headlamp levelling: Release
**** and remove nut securing headlamp
levelling switch to auxiliary switch panel.
3. Release 2 fasteners and open fascia access
panel.
4. Models with headlamp levelling: Remove
headlamp levelling switch from auxiliary switch
panel and disconnect multiplug.
5. Models with A/C: Remove 2 screws securing
in-car temperature sensor to auxiliary switch
panel.
6. Models with A/C: Disconnect multiplug from
in-car temperature sensor and remove from
7. Release 2 clips securing auxiliary switch panel
to fascia and remove panel.
Refit
1. Position auxiliary switch panel to fascia and clip
into position.
2. Models with A/C: Connect multiplug to in-car
temperature sensor.
3. Models with A/C: Position in-car temperature
sensor to auxiliary switch panel and secure with
screws.
4. Models with headlamp levelling: Position
headlamp levelling switch to auxiliary switch
panel and secure with nut.
5. Models with headlamp levelling: Replace
cap and connect multiplug to headlamp
levelling switch.
6. Connect multiplug to exterior mirror switch and
fit switch to auxiliary switch panel
