What is this box??
Old Aug 25, 2015 | 02:54 PM
caymandrew's Avatar
Default What is this box??
The lines from the fuel pump connect to it, then run out to the fuel rail. What is it? I can't find it in the rave?
Old Aug 25, 2015 | 03:06 PM
Paul Grant's Avatar
Charcoal cannister. It's an integral part of the evaporative emissions system on your truck.
Joemamma1954's Avatar
Looks to be the evaporative canister.
Old Aug 25, 2015 | 03:33 PM
Alphamale's Avatar
RAVE 17-2-3 EVAP canister.
Old Aug 26, 2015 | 08:03 AM
caymandrew's Avatar
Thanks guys. So if this box was submerged in a river for 5 days and now my truck won't start, I have air I have spark, after replacing the fuel pump, fuel rail, and injectors this would be a likely candidate as my issue?
Old Aug 26, 2015 | 08:32 AM
R0VERGUY's Avatar
I could be wrong but I don't believe any fuel lines run into the charcoal canister, only breather/vent lines run into the canister. I doubt that is your problem but you can always check if you like.
Have you checked fuel pressure yet? What are your SES codes again?
Old Aug 26, 2015 | 06:24 PM
Charlie_V's Avatar
That's right. No fuel passes through it. It is environmental crap for vapors.
Old Aug 26, 2015 | 06:27 PM
Charlie_V's Avatar
If you have no fuel always check the crank position sensor and the inertial switch. I'm guessing you had it pulled out of the river so I'd punch the inertial switch first. Passenger side firewall. Push down on it and hopefully you will hear a click.
Old Aug 27, 2015 | 05:41 AM
disc oh no's Avatar
No liquid fuel passes through it. However, there is a direct line going to the fuel tank. On the other side, where the vent valve is, it's open to atmosphere. I'm not sure if water could get in there, but if it did, it may pull water into the fuel tank when the evap monitor runs.
Maybe you should pull the fuel pump and siphon out all the fuel???
Or did you do that when you replaced the fuel pump?
ant996
Defender
Sep 14, 2006 05:03 AM
esblandrover
Sep 4, 2005 07:48 PM
Luv2Run
Aug 16, 2005 01:38 PM
ferrelltodd
Jul 24, 2005 01:22 AM
lugo35
Apr 21, 2005 05:03 PM
