What can stock really do?
Old Jan 10, 2014 | 04:57 PM
jafir's Avatar
The sticker in the door lists pressure at max load. The owners manuals shows much lower pressure for the rear tires under normal driving.
Old Jan 10, 2014 | 05:04 PM
Dane!'s Avatar
I don't think it would make a difference on mom tires if you deflate them or not, just my opinion though
For your stalling Id just check your seals that lead to your MAF, if there isn't a proper seal you'll stall. If your getting water up to your filter, which is just behind your headlight I'd suggest a snorkel and like previously stated, axle, trans, and xfer case extended breather lines. I got my snorkel for a 100$ off craigslist, I only have been in really deep water was in Utah one time, but it was a cool addition to my truck nonetheless
Old Jan 10, 2014 | 05:19 PM
ninjaff21's Avatar
Originally Posted by dusty1
I have 5, bearly used (1500-2000ish miles) bfg a/t ko on 18s if you want to deal. Just throwing that out there.
Are they 255/55/18 or 255/60/18 if so i may be interested depending on the price.
Also the water i went through i think i said it kind of misleading it was more of a mud pit it came up to maybe the top of the fog light but i hit it kind of fast and it went to limp mode and stalled
Old Jan 10, 2014 | 05:29 PM
dusty1's Avatar
Sorry, not exactly......275/65 r18.
Old Jan 10, 2014 | 06:28 PM
Madlands's Avatar
He prolly couldn't run those without a lift. 265/60r18 (30.5in) was the largest I could go on my 04 before the lift. They definantly wouldn't have fit my 99 and her old springs before the lift.
265/60r18 look real good on a stock D2. They should have come that size from the factory. I'm running the BFG Rugged Terrains in that size and they are nice and quiet on the road and perform surprisingly well offroad. Just my opinion...
Old Jan 10, 2014 | 06:47 PM
pinkytoe69's Avatar
Originally Posted by Madlands
265/60r18 look real good on a stock D2...
Agreed.
I have that size Cooper discoverer ht plus. Looks much better. It does rub something at full turn though
Edit: if anyone cares, these are often on buy 3 get 1 free at Pepboys and are a nice cross between a mom tire and an A/T...
Old Jan 10, 2014 | 07:07 PM
primussucks's Avatar
Might have a different issue.. Fog lights are no where near you MAF. Did you check to make sure your airbox was closed all the way? If it is all muddy inside then this *might* be your issue, i'm suspect though.
Like i mentioned, i've been in sustained water up to the middle of my headlights with no snorkel and fair just fine. I would have preferred a snorkel, but didn't have one.
I'd check your CKP personally.
Old Jan 10, 2014 | 07:44 PM
Madlands's Avatar
Originally Posted by pinkytoe69
Agreed.
That's crazy I never had mine rub. Maybe mine sat a little higher before the lift?
Old Jan 10, 2014 | 09:18 PM
pinkytoe69's Avatar
Yeah, mine sits pretty low...like 18.5" hub to arch.
Old Jan 10, 2014 | 10:35 PM
ninjaff21's Avatar
thanks for all the input and yes the box was closed i think my xyz switch is unprotected possibly if that had any affect. also after raining 2 days straight now im going to go off on some very muddy powerlines i suspect. anything i should do. any tips for going through some mud thats going to be very soft. im not much of a muder im better with rocky trails. (this trail is the one i belive i mentioned earlier)
