Old 08-31-2012, 01:25 AM
Rover De Land's Avatar
Default What did you do with your DII today?
Kinda like the DI side, but include what you did to it AND with it.
Yesterday - PULLED Tree out of pool that hurricanr put there.
Tonight - Changed transmission fluid and filter in my 03 also changed power steering fluid.
Tomorrow - Front U joints and center ball
Tip: autozone doesn't carry filter for 03 dii but ask about a say 98 D1 and they'll have it, exact same part.
The following 4 users liked this post by Rover De Land:
ChristianRover (07-13-2020), DiscoID (02-17-2021), Esco4227 (11-16-2018), OLFLA59 (06-12-2020)
Top Answer
11-30-2020, 07:57 PM
Discorama's Avatar
Discorama
Discorama is offline
Old Mojave Road, started at hwy 95 East to West. Stock suspension, only upgrade is 30.5" tires. Aired the tires down to 20/30. Used center lock sometimes, low range only one time. Piute Mountains is the hardest part, but the Land Rover took it with ease. Jeeps tried to ignore me. Mojave "River" crossing is only a few inches deep right now, water barely reached the rims.
Old 08-31-2012, 03:12 AM
FlyingZebra34's Avatar
To be honest, I haven't done anything than normal maintenance for awhile! It's a solid work horse!
Old 08-31-2012, 09:23 AM
dcarr1971's Avatar
Haven't moved mine on over week since I broke a motor mount and the fan exploded. (The fan took out the radiator, upper shroud, coolant return line, air box, and parts of the fan tried to punch up through the hood.). Then the shaft on the PAS pump decided to walk out about 4mm and shreaded the belt, so...
...in the last week I've done the following:
- Replace the radiator, fan, fan clutch, cooling return hose.
- Flushed and bled the cooling system.
- Replaced 2 motor mounts.
- Made a custom, 5-rib belt to get the truck home when it tried to slice 2 ribs off the existing belt. (All I did was trim the rest of the 2 ribs off, but I did it on the side of the road in the middle of the night!)
- Pulled and replaced the PAS pump with a brand new one.
Today,
- I'm re-bleeding the cooling system (temps just weren't stable enough for my liking before the fiasco with the PAS).
- Bleeding the PAS pump.
- Maybe (time permitting) replacing the rear drive shaft with a u-joint rear drive shaft. (I'm just tired of wasting $$$ on rotoflex couplers.)
The following 4 users liked this post by dcarr1971:
biosteve (12-22-2019), DiscoID (04-21-2020), Esco4227 (11-16-2018), mudpuppy229 (08-26-2017)
Old 08-31-2012, 09:28 AM
Today,
Dang that sounds bad...
And im trying to get the title fixed
Old 08-31-2012, 09:51 AM
dcarr1971's Avatar
It wasn't good, but I have backup Rovers, so I can usually find one to drive. I hate to think what it would have cost to repair all the damage if i was paying someone else. (Even with the new radiator, I only have about $375 in parts into the repairs + my time. This doesn't count the new PAS pump though...that was another $300...)
Old 08-31-2012, 09:58 AM
lr2001silver's Avatar
Banned
Damn Dave that sucks.
Spencer, good luck with that title!
I finally had to change my throttle body heater plate and gasket.
Old 08-31-2012, 10:03 AM
ZGPhoto's Avatar
Watched it sit outside work as I drove my new motorcycle
Old 08-31-2012, 10:51 AM
DiscoRover007's Avatar
Gave my truck a wash and detail. Going to do it again pretty soon. Just wanted to get it clean and get some wax on it since it has been sitting so long. The roof rack looks a lot better with the lights painted black, still looking to get a lower profile for them though.
Before...
After
The following 8 users liked this post by DiscoRover007:
cvhyatt (01-26-2020), DiscoID (04-21-2020), GunnerandDeena (10-27-2016), illbuildit (02-13-2016), Imi39 (09-09-2019), MargieFaye (05-13-2017), Murphy McManus (02-02-2020), Wheelspin (02-10-2023) and 3 others liked this post. (Show less...)
Old 08-31-2012, 11:04 AM
dcarr1971's Avatar
Originally Posted by lr2001silver
Damn Dave that sucks...
Thanks.
Forgot one other thing on the list today. I have to drop the tank skid and run it down to a local fab shop to add a 45* bend to better cover the back of by tank. After adding my new bumpers it's a little exposed, and I don't want the skid to act like a shovel if I have to reverse over something...
The following 2 users liked this post by dcarr1971:
DiscoID (04-21-2020), Sailor012 (09-23-2019)
Old 08-31-2012, 11:46 AM
Nice detailing!
Ill paint my fender flares once I'm sure it won't rain..
Water is still rising here our interstate and main highway strboth underwater so I had a little fun with that. On my way to get last u joint..
Quick Reply: What did you do with your DII today?
