Old Apr 18, 2014 | 05:59 PM
  #1621
ralphobell's Avatar
As much as the fuse will allow. Can't remember what fuse number it is but check the Rave or look on your truck.
Old Apr 18, 2014 | 06:13 PM
  #1622
SuperSport's Avatar
Rave says it's a shared fuse 20 AMPS.
Fuse #15 20Amps
Cigar lighter
Interior lights
Seat heaters
Vanity mirror illumination
Old Apr 18, 2014 | 06:49 PM
  #1623
jalodge's Avatar
I have plenty of wire so I guess I will just run it to the battery to save the delicate Rover electronic circuits. What size fuse should I use for the inline fuse.
Old Apr 18, 2014 | 08:47 PM
  #1624
ralphobell's Avatar
3 Amp fuse should be fine. They should only charge at most 2.1 Amps.
Old Apr 19, 2014 | 04:01 AM
  #1625
sparkenzap's Avatar
I would tap into the cigarette lighter circuit. The "delicate" electronics are much more likley to get disturbed by the process of running the wire back to the battery and the adapter will never draw more than an amp or so. It is a PWM converter and power, not current, is the issue. (Power = volts times amps).
Old Apr 19, 2014 | 07:40 AM
  #1626
jalodge's Avatar
How can running a wire from the battery affect the rest of the electrical system?
Old Apr 19, 2014 | 08:37 AM
  #1627
ralphobell's Avatar
It's a Rover that's why.
I use these and they work great.
Old Apr 19, 2014 | 08:42 AM
  #1628
jalodge's Avatar
So y'all are saying it is better to risk overloading a circuit than running a new one?
Old Apr 19, 2014 | 08:55 AM
  #1629
sparkenzap's Avatar
There is no possible way to "overload" the cigarette lighter by running a usb charger from it unless the charger becomes defective. Then, the fuse blows and you replace the charger and the fuse. Until you do, the cigarette lighter does not work. The engine doesn't fall to the ground, the gas tank does not blow up, the ecu does not fail and so on.
My statement about affecting the existing wiring is that while you are snaking the wire in, you might skin another wire or dislodge some connector, or make a new less watertight penetration. Not likley, but just sayin, there is risk in anything.
BTW, when you plug your phone charger in at your house, do you worry about blowing your TV?
Old Apr 19, 2014 | 11:20 AM
  #1630
ralphobell's Avatar
I use what I displayed above because I don't like tapping into existing wiring. Very difficult to troubleshoot later. Plus I know that it is on a dedicated circuit.
