Old Jan 26, 2016 | 11:34 PM
  #3091
number9's Avatar
Originally Posted by jamieb
I originally used metal rigid fuel line and a pipe bender. Finally went back to OEM tubing with the new radiator.
A friend of mind asked me why LR didn't use metal rather than plastic on those lines. A 1st thought might be cost as primary factor. In the real world there are disadvantages to metal line as well such as fatigue failures and being less flexible to allow easier mx in surrounding area.
I'm fairly certain that mine had not been replaced since new and simply shattered due to age. Those plastic lines should be replaced with new as a PM item every ?? years or so. Similar PM replacement would be advisable if heater/coolant hose was used as a substitute.
Old Jan 27, 2016 | 12:56 AM
  #3092
number9's Avatar
Default Thermostat R&R
Replaced my thermostat a couple of days ago with a PEM100990 eurospare branded replacement. Cruising at 60 MPH, temps steady at 188 F and idle is in low to mid 190s which is about a 5 degrees lower than before. No temp swings yet and will report back after further evaluation.
Old discolored stat was probably installed at the LR factory as it has the older plastic molded on date of 11-03 on housing. I'd previously removed it during several recent system cleanings/flushes and removed debris from the top of by-pass valve. Included photo shows what accumulated in just the week prior to replacement. Most of the chunks appear to have come from the
disintegrating by-pass valve entry hose fitting that's subjected to the highest coolant temps. Fortunately the valve doesn't open enough to allow the large stuff to pass.
Old Jan 27, 2016 | 04:40 AM
  #3093
ckadventure's Avatar
Originally Posted by Shiftonthefly1
Took the truck for a Utah road trip. This thing is great in the snow. Went to Zion and did some light off roading in that area. Then up in the hills to a cabin w my dogs.
Very nice!!!!
Old Jan 27, 2016 | 09:39 AM
  #3094
OEMPartHaus.com's Avatar
Former Sponsor
I'll be installing Magnaflow 16888 tonight, hopefully.
Old Jan 28, 2016 | 08:53 AM
  #3095
Tennessee Disco's Avatar
8th Gear
Lucky8 front driveshaft on and greased. Had no problems, except the piece of plate metal welded onto the side of the shaft (for balancing, I assume) was attached right up against the grease nipple, and I couldn't get my grease gun to attach. Had to unscrew it just enough that grease still entered the shaft but without completely removing the nipple. Now I have to figure out the SES codes for a misfire in cylinder 4. what's the best place to start?
Old Jan 28, 2016 | 01:09 PM
  #3096
dgi 07's Avatar
Chasing P1171/P1174
Attached Thumbnails What did you do with your DII today?-1454008814441790943761.jpg
Old Jan 28, 2016 | 04:58 PM
  #3097
number9's Avatar
Originally Posted by dgi 07
Chasing P1171/P1174
Change your air filter element just prior to getting codes?
Old Jan 28, 2016 | 09:29 PM
  #3098
rossagge's Avatar
Oil and filter chg today. Used Rotella T6 15W-40. Noticed the ticking has gone down from loud to just noticeable. Ordering new lower and upper hoses as well as thermostat since the upper hose from the T to the thermostat came off while driving only less than 5 miles down the road. Started to overheat, but shut it down just in time. Couldn't get it to stay on since I didn't have my vice grips for the clamps. Lesson learned! Going to purge the entire system, replace hoses and thermostat.
Side note...never realized that gurgling sound was due to air trapped in there and needed to be bled!
Old Jan 28, 2016 | 11:22 PM
  #3099
number9's Avatar
Worm-gear clamps as well?
Old Jan 28, 2016 | 11:48 PM
  #3100
rossagge's Avatar
Nah, meant to say I couldn't compress them enough even with my gloved hands to fit the clamp over the hose and thermostat. Still, they must be a little worn for the hose to slip off clamped. With that said, I think I'll replace those as well with the screw down style clamp.
