Old Nov 13, 2016 | 11:32 AM
  #3461
scottmb23's Avatar
A week or so old but finally got around to the Three Amigo fix 'Option-B' and all has been good. I put this off for so long, telling myself it was outside of my skill set, couldn't be further from the truth, this really is a simple fix - if you have those pesky Three Amigos, this is a must!
Old Nov 13, 2016 | 03:35 PM
  #3462
The Deputy's Avatar
Default 01 Discovery
Exhaust on, trans. fluid filled, locked CDL, road test...she moves...hurray!
Brian.
Old Nov 15, 2016 | 07:18 AM
  #3463
JUKE179r's Avatar
Default Blower motor cleaned up
took a part the blower motor since it sounded like crap. Cleaned and lubed it along with the cleaning the heat sink. It's quieter and seems like it blows more air.
Old Nov 15, 2016 | 06:28 PM
  #3464
Jeff Blake's Avatar
Gave my exhaust manifolds a beauty treatment
- Dunked in distilled vinegar overnight
- Dunked in baking soda to neutralize acid
- wire brushed like mad to get rid of all rust
- dried and immediately sprayed with wd40
- dried again, cleaned with mineral spirits
- a few coats of CRC Dry Graphite Lube to make them pretty. This isn't paint, and its supposed to withstand the heat and retain the look.
Not the greatest before photo (this is my attempt and sanding - no dice)
After their bath
Old Nov 15, 2016 | 11:43 PM
  #3465
Rlozano's Avatar
After their bath
Wow those look great, nice job.
Old Nov 18, 2016 | 02:55 PM
  #3466
JUKE179r's Avatar
Great job Jeff Blake!
I wish I could sand blast my exhaust manifolds and ceramic paint them. I'm too worried about stripped nuts and studs when trying to remove my exhaust manifold.
Old Nov 18, 2016 | 03:32 PM
  #3467
Thatguy63's Avatar
new tires new serpentine belt new brakes and fixed my windshield washer reservoir
moving to Indiana to start a new rover club and continue my restoration
Old Nov 19, 2016 | 06:50 PM
  #3468
Jeff Blake's Avatar
Just say no to adjustable ring compressors...
Going to buy an ARP 94mm tapered ring compressor instead...
Old Nov 23, 2016 | 02:12 PM
  #3469
JUKE179r's Avatar
I found out the hard way that the tubes to the windscreen washers have 2 miniature check valves in them.
I was going to take a picture and post the small ball bearing and spring but I bloody lost them both. Aaaaaaargh!
Old Nov 24, 2016 | 04:42 AM
  #3470
The Deputy's Avatar
Installed two front drive shafts last night, so both Discovery's are once again...moving. Was going to start on the engine work on the 03, but decided to drive it for a bit. There are a couple things I'd like to do on her, and doing these tasks at work...on the hoist...just makes things easier.
Took the 01 for its first ride with everything completely done on the tranny install. She drives nice and no lights on the dash...hurray. I'll get plates this week coming up, and put some miles on her...before handing her off to my wife.
I'm going to drive the 01 across the field out back, which has a nice deep ditch intersecting it...so wish me luck.
Brian.
