Old Apr 28, 2017 | 10:36 AM
  #3931
Luckyjayb's Avatar
Originally Posted by Disco Dad
I've been wanting to do this for a while. I think it turned out great!
it does look good. Need a write up on that one
Old Apr 28, 2017 | 11:26 AM
  #3932
Disco Dad's Avatar
I found this and then went my own way....
https://landroverforums.com/forum/di...rite-up-33088/
Old Apr 28, 2017 | 11:31 AM
  #3933
naivedisco2's Avatar
Big week for my Rover, finally set aside some time and money to get things sorted correctly. First up, new coil packs, Kingsbourne 8mm wires, Champion double plats, and new intake manifold gasket, fixed my chronic misfire issue! One bolt was missing from the intake manifold, so I replaced that as well.
Also swapped all four motor / transmission mounts, pain in the butt but I got them all done after work one evening, thanks to RAVE and a write up on the forums. 3 out of 4 were completely broken in two.
Finally, got my brand new 245/75/r16 BFG KO2s mounted. Fixed my wobble / steering wheel shake at 50 MPH and look way better than the hodgepodge street tires I had before. Other than fluids, I hope to be good on major work for a bit.
Old Apr 29, 2017 | 03:57 PM
  #3934
dialtonehero57's Avatar
Nice work
Old Apr 29, 2017 | 05:10 PM
  #3935
Jeff Blake's Avatar
Floor done
next up a storage box/ cubby and a fridge slide on top
Old Apr 29, 2017 | 05:26 PM
  #3936
Friday Night Disco's Avatar
@ Jeff Black - Your TP to bungee cord ratio is off
Old Apr 29, 2017 | 06:28 PM
  #3937
The Deputy's Avatar
Default Long story short...
I fixed the code PO705 today on my wife's 03.
Ever since I put the engine in, code PO705 has been present. Had flashing M & S green lights on dash and CEL on constantly, key wouldn't come out of ignition, and was in lock up, 3rd and reverse only available gearing. Been going the usual route, replaced battery terminals, nothing, checked battery and charging system, nothing, replaced WXYZ switch on trans, nothing, checked new and used switch with ohm meter, nothing different about the two.
So, removed the window switch panel inside to get at the trans harness...to check for broken wire. Lowandbehold...wire broken...or I should say "chewed" apart by a small creature, mouse.
Blue and purple wire next to white connector in picture below.
Better picture of the destruction.
Repaired wire, electrical taped area...and problem solved. I'd notice earlier that the boot on the main wiring harness going through the firewall was pulled out...just enough room for a mouse to make entry. And I'd thought I'd heard something in the dash when starting the vehicle for the first time, after motor install, but didn't give it much more thought.
Anyhow, the nightmare is finally over...been struggling with this for a week now. Smoked a celebratory cigar to help embrace the moment. Earlier in the day, I'd thought about using the bic lighter to light something else on fire...lol.
But...
All's well that ends well.
Brian.
Old Apr 29, 2017 | 06:34 PM
  #3938
The Deputy's Avatar
Default Attention jeff!!!
These are the straps, four in a bag. They do not ratch, you pull them tight and then the handle levers over to tighten them more.
We have some different styles, but I was short on time yesterday...so searching through binds was limited.
Don't know if you saw this or not.
Brian.
Old Apr 29, 2017 | 07:35 PM
  #3939
Jeff Blake's Avatar
Hey Brian - yeah those look great. Nice and short, too. Everything out there is like 8 feet long. Possibly a bit too heavy duty... I guess I'd need 4 (maybe 2 depending on box) per box to secure it.
I want to secure a cubby box w/ fridge on top. 4 corners, so 4 straps there
pelican case - just one strap each side
toolbox - one per side probably
Some more items TBD
What are you proposing?
Old Apr 29, 2017 | 10:02 PM
  #3940
Zonk872's Avatar
New transparent white expansion tank with cap for under $50.00 including shipping on EBay 👍🏻
Hose was zip tied after photo...
Old expansion tank (original) with second cap. D2 currently has just under 62k.
Decided not to use the barb and connect to existing hose (intake to t-body) and route behind intake.
Plan B (after intake barb hose to oil separator broke. Ran new 5/16" fuel hose from top of intake barb directly to expansion tank.
New brass barb... added epoxy bead to joint of butted brass barb to intake manifold.
Throttle body bypass... hard way after breaking plastic barb on the intake manifold. Removed upper intake... cleaned debris from barb. Replaced expensive OEM barb with brass barb for 1/4 the cost. Installed 5/16" fuel hose from intake directly to new expansion tank.
