Old Jun 5, 2018 | 12:04 PM
  #5441
Chemcorp158's Avatar
Cussed at it The Demon while adding my morning coolant. Cussed at myself for not doing option B yet when the Amigos came on after the customary 200 feet out of my driveway. I always smile for those 200' in the mornings when there are no lights on, too bad it is always short lived.
Old Jun 5, 2018 | 06:27 PM
  #5442
razorkill12's Avatar
Originally Posted by No Doubt
Leaky fuel injector could also drop fuel pressure after cutoff.
Literally just did head gaskets and also replaced all injectors
Old Jun 5, 2018 | 09:32 PM
  #5443
Saturnine's Avatar
Doesn't mean that an injector could be seated incorrectly or something
Maybe the hard line has a hole / crack in it on the back side of the IM?
Old Jun 6, 2018 | 08:18 AM
  #5444
naivedisco2's Avatar
Used it to haul my new toy!!! Could definitely use some more powerful brakes but generally towed just fine. Starting to see a pattern here - now we have two V8 Rovers and a V8 boat. Had to replace a couple of things right off the bat after buying the boat... I think it will feel at home parked behind the Rovers.
Old Jun 6, 2018 | 09:04 PM
  #5445
Sixpack577's Avatar
Tried to put valve covers on...tried.
Gaskets are junk, top front hole is punched over 3/8" off center(both gaskets, and both heads and valve covers are the same, so they are nondirectional, and gaskets cannot be flipped over).
Since the gaskets fit the valve cover, and the metal insert is pressed into the gasket for the bolt holes, and the top front doesn't line up...if you put the bolt through the hole first, there's a nice 3" part of the gasket around the bolt hole that is pushed down and out over the intake.
The whole gasket is too long too!
Another set back, and over junk parts. Yay.
Anyone else seen that before?
Old Jun 6, 2018 | 09:13 PM
  #5446
The Deputy's Avatar
Switches for light bar and rear lights. Ran wires and installed three relays, one for each set of lights.
Head lights.
Head lights and brush guard lights.
Head lights, brush guard and light bar lights.
Brian.
Old Jun 8, 2018 | 01:55 PM
  #5447
No Doubt's Avatar
Sharp! And fun! What's the skinny on the boat? Type? Price? Use?
Old Jun 8, 2018 | 01:57 PM
  #5448
Saturnine's Avatar
Stoked.
Old Jun 8, 2018 | 04:21 PM
  #5449
jamestfl's Avatar
Donzi. 21-23 ft?? going fast...
Old Jun 8, 2018 | 08:14 PM
  #5450
Originally Posted by Saturnine
Stoked.
Congrats man you earned that Pass
