Old Jul 1, 2018 | 09:46 AM
  #5561
Friday Night Disco's Avatar
Two weeks ago I increased the turning radius of Tricky Dick by getting a couple bolts and nuts at the local hardware store and swapping out the stock bump stop bolts. I set it up so I can adjust as needed, incase there was rubbing.
So far it has been fantastic! No rubbing and I have significantly more maneuverability
I am running 18" rims with 255/55/18 tires
Old Jul 1, 2018 | 11:29 AM
  #5562
Saturnine's Avatar
Umm.. tell me more. You mean like turning radius?
Old Jul 1, 2018 | 11:34 AM
  #5563
Best4x4's Avatar
Yeah I covered this a while back with the custom ones I installed on my Kalahari. 16inch & 18inch D2’s come with different turn stop lengths. It’s honestly a mixed 50/50 shot on what your D2 actually ships with, but normally 16inch equipped D2’s had shorter turn stops vs 18inch equipped D2’s.
You just need like above a nut/bolt or like what I’ve done in the past a shorter bolt with washers so you can adjust it via the washers. My Kalahari is using a bolt and a collar that is exactly the size I needed for my turning radius to be spot on without any rubbing.
Old Jul 1, 2018 | 11:37 AM
  #5564
Yes!! I didn't measure the new turning radius but, I definitely got a few feet back by reducing the bump stop by 1/4"
Before, I had to do a three point turn when I backed out of my garage, now I simply back out with the wheel turned to the right and go forward.
I made it so I could adjust, if I ever decide to go with a wider or taller tire.
Old Jul 1, 2018 | 12:17 PM
  #5565
Best4x4's Avatar
Yep it makes a HUGE difference.
Old Jul 1, 2018 | 05:06 PM
  #5566
No Doubt's Avatar
This thread is a great idea. Thanks for posting! Also, would be even better with before/after pics of bump stops and different turning radiuses...
Old Jul 1, 2018 | 05:09 PM
  #5567
No Doubt's Avatar
Talking
Went rovering in Ohio.
About 700 miles round trip, no issues.
Brian.
Yeah, Baby!
Old Jul 1, 2018 | 05:10 PM
  #5568
No Doubt's Avatar
Originally Posted by COSitsWORTHit
Installed my rock sliders
I'm officially jealous. Great look. Also, that's a really good looking lift height. 2 inches??
Old Jul 1, 2018 | 05:13 PM
  #5569
No Doubt's Avatar
I cleaned out the A/C blower fan cage today. Holy smokes what a difference when I reinstalled it without being stuffed full of leaves!
Old Jul 1, 2018 | 05:34 PM
  #5570
Saturnine's Avatar
Just pulled mine out, they measured right about 7/8" -- these are probably for the 18's, right?
