Old 10-21-2018, 12:58 PM
escott16's Avatar
Originally Posted by vwauditech
Should be ~$300 with the bedliner paint. All the metal was $285. That included having the metal shop cutting everything to my specs.
I wish there was someone who could make a replica sd or Baja rack for cheap , I really want one but I can’t justify spending well over 1k for it considering a ls swap is in the near future
  #6042
Old 10-22-2018, 10:39 AM
mln01's Avatar
Originally Posted by Saturnine
Poked around the front drive shaft again, still getting a slight vibration at hwy speed. Turns out the shaft / yoke zerk fitting was never installed -- removed the allen set screw, installed a zerk and greased it up. I don't think there was any in there grease in it at all Hopefully i havent fubard the shaft!
Originally Posted by ThisRoverGuy
mine was the exact same when i got it. Took about a year of ownership before i realized that there was an Allen screw in there and that it was the perfect size for a zerk. Added the zerk and went to town.
The zerk should be removed and replaced with the allen screw after greasing the splines. There is a risk, however small, that if left in place the zerk might hit the crossmember if the front axle is articulated to its limit.
jastutte (10-22-2018)
  #6043
Old 10-22-2018, 03:48 PM
R0VERGUY's Avatar
Pulled my SAI manifolds for some fresh heat wrap. The black looks great on there. I used this same stuff for the last 50k miles and it's held up fantastic. I bought 4 feet three years ago and I still have enough to do this again in another 50k.
  #6044
Old 10-22-2018, 07:03 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
That OEM white stuff just turns to dust on the SAI stacks. Where did you get 4ft of that black wrap?
  #6045
Old 10-22-2018, 07:44 PM
mollusc's Avatar
What purpose does the wrapping serve? I was just going to leave it off.
  #6046
Old 10-22-2018, 10:01 PM
Saturnine's Avatar
I did not think about this
I'll check that tomorrow.
  #6047
Old 10-22-2018, 10:02 PM
Saturnine's Avatar
Mine aren't covered with anything
  #6048
Old 10-22-2018, 10:09 PM
Best4x4's Avatar
The OEM heat wrap was supposed to keep the temps from the exhaust, but it quickly dissolved into pieces and fell off. I've run SAI trucks for years with nothing on them and zero issues. However Roverguy had a great way of installing new heat wrap onto them.
  #6049
Old 10-23-2018, 02:30 AM
The Deputy's Avatar
Received 1,278 Likes on 897 Posts
Most likely, the heat shield is there to reduce heat transfer around the plug wires, or just to keep unsecured plug wires, fluids or a persons fingers from coming in contact with the hot tube.
Brian.
  #6050
Old 10-23-2018, 02:32 AM
The Deputy's Avatar
Or to hide the cheap quality of them...lol.
Removed them entirely on 01, good riddens.
​​​​​​​ Brian.
Quick Reply: What did you do with your DII today?
