Old May 3, 2013 | 10:03 AM
  #601
Dan7's Avatar
Pulled the upper intake/coils out to find out where my CPS female plug went...yippie!
Old May 3, 2013 | 11:53 PM
  #602
Street Wolf's Avatar
Originally Posted by MuddMouth
Looks good but man u need sliders dude!!!
Gimme.
Old May 4, 2013 | 02:19 AM
  #603
Oh, and...
New mirror, it's beautifuuuul.
Old May 4, 2013 | 03:49 AM
  #604
MuddMouth's Avatar
Originally Posted by Street Wolf
Gimme.
Show me your ***** and I think about it!!!!!!
Old May 4, 2013 | 04:39 PM
  #605
Swwwweeeeet. Brb, got to find my camera.
Old May 5, 2013 | 10:02 AM
  #606
poncePR's Avatar
Finally removed sagging headliner(to recover or paint) and found source of front sunroof leakage(2 broken drain tube connections).Also front sunroof motor not working and rear sunroof opens on It's own but won't close....fun stuff.
Old May 5, 2013 | 10:43 AM
  #607
poncePR's Avatar
....opened up non working front sunroof motor,had some rust.I cleaned it with left over MAF cleaner and now working good!....now just gotta figure out why rear sunroof opens but won't close.
Old May 5, 2013 | 11:22 AM
  #608
Barat11's Avatar
8th Gear
Question
Replaced bad auxiliary fan with junk yard special. Continue to trace oil leaks by cleaning and checking.
I think my compressor motor for air suspension is loud but do not have anything to compare it to. Anyone reading, when your compressor kicks in can you hear it? And if so how loud is it?
2000 Disco
Old May 5, 2013 | 03:45 PM
  #609
Nftyper's Avatar
installed new rotors and pads all around.
Old May 6, 2013 | 09:51 AM
  #610
jdwilks's Avatar
After a few days of rain my driver rear blinker light housing was filled with 2 inched of water. I had taken it apart a month or so back because of a burnt out bulb that had rusted inside the socket. Cleaned it and let it dry out and used electro grease on it and has been working fine but with that much water wasn't going to last. Discovered that by hand I could pull the lens off the housing in one corner. Used a heat gun and removed it the rest of the way.
I had noticed my that lens looked darker than the passenger side but I assumed it might be just mold in between the layers of lens. Well after talking it apart I realized all the chrome had worn away inside the housing. Guessing from water but not sure. I had some chrome paint in the garage so gave the inside of the housing a good sanding and got some paint on them. Figure I never use the rear fog and the blinkers are not on long periods of time so the paint should hold up ok since wont be much bulb heat. Got them resealed some colear silicone and for added protection wrapped them in some black gorilla tape along the top were the housing meets the lens. Probably not the best thing I could do but figure it might help. You can't see it and now both lenses look the same color from the back so I was happy for a few hours work
Still need to remove my headliner and track down the leaking roof. I am pretty sure its the rear sunroof but havent had time just yet to scope it out. Not leaking bad and headliner needs replaced anyway
