Old Apr 20, 2019 | 08:36 AM
  #6571
The_OGCJR's Avatar
Those stainless steel cup holders are cool!
Old Apr 20, 2019 | 04:34 PM
  #6572
escott16's Avatar
Repainting the rack I found on Craigslist
Old Apr 20, 2019 | 07:28 PM
  #6573
Nosugar0carbs's Avatar
Default Metal headlamp guards
Installed new guards up front, main beam housing and fog lamp as well.
Old Apr 20, 2019 | 10:38 PM
  #6574
lordmorpheus's Avatar
Default Long time away..
Sorry I've been gone for years. Long story.
Not today, but several months ago: Ran into one of those rebar reinforced concrete parking lot posts at about 15mph. Came to a quick stop. Driver's door wouldn't open fully. Coolant all over the ground, bumper pieces all over. Had it towed to work where I removed the outer fender and pried the inner fender off the tire so it could at least move.
Luckily, I had a donor Disco in my driveway 120 miles away (Long story of a divorce and living with my father while wife lives in my home).
Towed my Disco to my old hometown, and the donor towed to a friend's shop where I began to drill out spot welds to remove the left inner fender and front bulkhead. Roughly 74 spot welds per vehicle. Three days later and I had a complete vehicle. Paint will come eventually, and also the brushguard after I mend it.
Nothing I can't fix...
74 spot welds separated.
Donor Disco
Done!
Old Apr 21, 2019 | 04:06 PM
  #6575
Pavilion's Avatar
Nice work! Sorry to hear of your troubles, She got the palace at least you got the Landy! Best attempt at humor for something that just isnt funny. Hope things smooth out for ya!
I too have been busy today. Finally got to the bottom of my misfires. Seems engines want to suck air only into their cylinders. Good news is the head and block are straight with no corrosion so a clean up and new gaskets and we are good to go. You can see by the pics the valve covers were leaking badly and I found the intake loose so it just sucked the oil straight in.There were also several water leaks with hoses on the intake bleeding into the valley so that where the water came from to clean the pistons. There is also several of the valves with build up leaking by.
See the oil in the intake ports? been there a while!
Old Apr 21, 2019 | 09:16 PM
  #6576
Thanks! Really my first go at major bodywork. I was quite surprised at how well it turned out. All body lines are straight and true.
Old Apr 21, 2019 | 10:19 PM
  #6577
Texsun's Avatar
7th Gear
It took about 2 hours to get the factory bumper off and all of 3 minutes to install the new bumper including opening the box... Also, installed some LED light, and did the silicone to make them actually waterproof. Still waiting on the winch to arrive, so that will be next!
Old Apr 21, 2019 | 10:49 PM
  #6578
Texsun's Avatar
7th Gear
Also, flowmaster exhaust...
Old Apr 22, 2019 | 06:47 AM
  #6579
The Deputy's Avatar
Not sure if it is just a poor photo, or my poor eyesight, or material from gasket...but that fourth lifter looks as though the retaining clip has popped out or is broken. Had five lifters in this condition, when I removed my wife's 03 engine.
Brian.
Old Apr 22, 2019 | 09:46 AM
  #6580
JohnHZ3's Avatar
I like these better than the plastic ones I have. Where did you get them and what are the part numbers? Looks great!
