Old 04-23-2020, 07:08 PM
merebel's Avatar
Originally Posted by boston4
Is this the one from southern New Hampshire?? I was eyeing it and thinking of going to get it this weekend but it got updated today as being sold!
beat you too it and on the way back we started with the vibration
  #7432
Old 04-25-2020, 12:08 AM
No Doubt's Avatar
Rescued my mom's new Lexus that had a dead battery (happens??) and filled up my Disco from E for $30.
The following 3 users liked this post by No Doubt:
cvhyatt (04-28-2020), HuskerRover (04-26-2020), JUKE179r (04-27-2020)
  #7433
Old 04-25-2020, 08:30 AM
Rushjob's Avatar
4th Gear
A morning of maintenance... changed the turbo gasket (TD5) topped up the transmission fluid and carried out the shuttle valve mod to get rid of the recurring 3 amigos. All in all, a satisfying day and now it's time for a beer
The following 2 users liked this post by Rushjob:
DiscoID (04-25-2020), No Doubt (04-25-2020)
  #7434
Old 04-25-2020, 09:31 AM
DiscoID's Avatar
Replaced the front shaft with one from Lucky8 yesterday after work. Piece of mind and safety for the transmission, along with the ability to grease all points at regular intervals.
  #7435
Old 04-25-2020, 07:01 PM
DCDisco2's Avatar
Replaced my 2nd row ash tray with a Tuffrok power panel. Haven’t finished the wiring yet, waiting for a member to respond with the hookup on the accessory power plugs he was selling.
  #7436
Old 04-26-2020, 12:00 AM
No Doubt's Avatar
  #7437
Old 04-26-2020, 02:39 PM
Nosugar0carbs's Avatar
Wife picked out an early present and had it shipped. Nothin fancy but it is the thought that counts. Just the side marker guards.
Pre
Post
The following 2 users liked this post by Nosugar0carbs:
No Doubt (04-26-2020), RossN99 (04-26-2020)
  #7438
Old 04-26-2020, 07:24 PM
HuskerRover's Avatar
I have also outfitted mine with the same prop. Great deal. They say no more tha a 1" lift but for my use my Disco is tall enough.
DiscoID (04-27-2020)
  #7439
Old 04-27-2020, 08:02 AM
redrover75's Avatar
Did a smoke test to find my vacuum leak, no leak, but found SAI pump was not plugged in. That thing is loud! Will take it apart, see if I can quiet it down. I don't think I have ever heard one before, in 6+ years of ownership. Now, I have a different set of codes, cleared a few and now I have P1412, P1415, P1884. Not sure why have the transmission fault. Will need to dig into it.
  #7440
Old 04-27-2020, 08:20 AM
NewToTheTwo's Avatar
Leaky valley pan gasket
Removed intake plenum - fuel rail/injectors - coil packs - spark plugs/wires - alternator/ac compressor and its bracket
All 12 intake bolts were loose - removed one by one, applied blue loctite, re-torqued to spec.
Replaced injectors with rebuilt/tested set
New Bosch coil packs - Bosch plugs - STI wires
Upper intake bolts were loose too - retorqued and loctite applied on reassembly
Flushed coolant - at 220k miles replaced Dexcool with Prestone - flushed with 7 gallons of distilled water
NOTHING LEAKS NOW - no oil, on water, no nothing... LOL
*****If you feel you're valley pan is leaking - look at re-torquing bolts - lots of old threads/posts about this - common issue for those bolts to come loose*****
Quick Reply: What did you do with your DII today?
