A morning of maintenance... changed the turbo gasket (TD5) topped up the transmission fluid and carried out the shuttle valve mod to get rid of the recurring 3 amigos. All in all, a satisfying day and now it's time for a beer
Did a smoke test to find my vacuum leak, no leak, but found SAI pump was not plugged in. That thing is loud! Will take it apart, see if I can quiet it down. I don't think I have ever heard one before, in 6+ years of ownership. Now, I have a different set of codes, cleared a few and now I have P1412, P1415, P1884. Not sure why have the transmission fault. Will need to dig into it.
Leaky valley pan gasket
Removed intake plenum - fuel rail/injectors - coil packs - spark plugs/wires - alternator/ac compressor and its bracket
All 12 intake bolts were loose - removed one by one, applied blue loctite, re-torqued to spec.
Replaced injectors with rebuilt/tested set
New Bosch coil packs - Bosch plugs - STI wires
Upper intake bolts were loose too - retorqued and loctite applied on reassembly
Flushed coolant - at 220k miles replaced Dexcool with Prestone - flushed with 7 gallons of distilled water
NOTHING LEAKS NOW
- no oil, on water, no nothing... LOL
*****If you feel you're valley pan is leaking - look at re-torquing bolts - lots of old threads/posts about this - common issue for those bolts to come loose*****
NOTHING LEAKS NOW
- no oil, on water, no nothing... LOL*****If you feel you're valley pan is leaking - look at re-torquing bolts - lots of old threads/posts about this - common issue for those bolts to come loose*****
