What Direction Does the Coolant Flow?
Old Oct 12, 2018 | 01:04 AM
abran's Avatar
Originally Posted by 99FLDISCOII
radiator has a bow. the tubes are not perfectly straight, there are also 47 tubes and allot more fins than the Stock ... hoping gravity will help the water move faster..
Buy a Discovery 5, problem solved.
Old Oct 12, 2018 | 10:05 AM
Sixpack577's Avatar
Keep bashing the guy for moving his business because it's inconvinient for you too.
For someone that's always putting down people who shouldn't own Land Rovers because they can't work on them...sounds like you need help working on yours??
Maybe it's just me...maybe it's karma??
Old Oct 12, 2018 | 11:32 AM
escott16's Avatar
Flows directly into the garage floor
Old Oct 12, 2018 | 03:33 PM
Richard Gallant's Avatar
For the OP how is gravity going to to help a closed pressurized system ? As well with a decent fan/clutch combo, and 180 thermostat and good water pump you will be running 185 to 197 under normal conditions even with a stock rad. That is kinda of the sweet spot for these trucks.
On mine if I work it hard up hill and it gets to over 200 the clutch kicks in and coasting down hill I hit 180 -181 for about a a klic, then back to normal at 188ish. That is with a Nissen's rad of unknown age and the same with water pump. If I could get a good well made higher capacity rad I would consider it, but I would not buy any cooling system part of doubtful manufacture for any aluminium engine that is just asking for trouble. And yours sound pretty iffy to me.
Old Oct 13, 2018 | 06:17 AM
The Deputy's Avatar
Was thinking the same EXACT thing. He has that one ridiculous rant post, about folks not deserving to own a rover...then every post afterwards is about him not having the money or buying crap parts or not having the knowledge to fix his...lol.
Some of this you just can't make up...sometimes truth is stranger than fiction...lol.
Brian.
mln01
Oct 12, 2021 07:33 AM
Brandon318
Jun 3, 2019 04:20 PM
Sandman614
Sep 26, 2018 08:34 AM
Flyin2jz
Jul 23, 2012 12:45 PM
