What do I need to get my 2000 disco 4x4 ready
Old Feb 16, 2013 | 03:46 PM
Tracecroft91's Avatar
Default What do I need to get my 2000 disco 4x4 ready
What do I need to get my 2000 disco 4x4 ready. I already have 2 in lift coil's on it an open country tires on it. What else would I need for it but I want to still take it on the road also.
Old Feb 16, 2013 | 04:23 PM
bballjames's Avatar
Locking CDL will one thing that will make a huge difference. You can manually lock it by climbing under the truck with a 10mm open wrench, or you can get a D1 shifter linkage and jimmy rig it or get an 04 linkage and bolt right in.
Old Feb 16, 2013 | 05:01 PM
Ok I am new to this so will I have to unlock it every time I drive on road
Old Feb 16, 2013 | 05:06 PM
Bkreutz's Avatar
Yes you do
Old Feb 17, 2013 | 12:25 AM
toofaroffroad's Avatar
Get your CDL working and you are good to go. Might want to invest in a winch or make sure you've got a friend with one.
Old Feb 17, 2013 | 12:55 AM
FlyingZebra34's Avatar
If the winch is too much a highlift jack will get you un stuck with some work. The CDL shift from a D1 is an awesome way to go and is very common. It will require some work on your part though. You can get one from the salvage yard for probably $40 (it's around what I paid) ... if there aren't any salvage yards near you send me a message and I can ship one too you.
For the install, you will need to remove your center console and remove the existing Hi/Low shifter, cut the plate and install the "new" shifting assembly.
soonerswin
Mar 14, 2014 10:18 PM
MarkSF
Feb 7, 2014 02:13 PM
ugottooffroad
Jul 10, 2013 11:08 AM
Evan Wiley
Dec 31, 2012 03:43 PM
adigerol77
Jul 16, 2011 09:11 PM
