What do you know about this lift kit?
Old Sep 23, 2009 | 11:17 PM
Frank4's Avatar
Default What do you know about this lift kit?
Performance Shock & Spring Kit - Super Gaz - Front & Rear - 1.6" Lift
I was looking around on Atlantic British and saw this kit. Look like a deal. I know most people like the Old Man Emu kits etc. Is this kit too good to be true?
Click the link: http://www.roverparts.com/Parts/8573.cfm
Old Sep 23, 2009 | 11:26 PM
98roverguy's Avatar
I doubt anyone here will advise you on getting that. Why not spend an extra $75 and go with what everyone knows and trusts? They even have a video on how to do it.
http://www.lucky8llc.com/Products.asp?ProductID=2152
Old Sep 24, 2009 | 07:28 AM
okdiscoguy's Avatar
The Super Gaz setup is big in the UK, but for what goes into it, the OME holds up a lot better. Spend the extra few bucks and get the good stuff.
Old Sep 24, 2009 | 07:59 AM
Ditto, get the OME, it will serve you better and you can pick between light, medium, H.D or extra H.D.
Don't forget to also order a steering stabilizer.
Old Sep 24, 2009 | 08:02 AM
okdiscoguy's Avatar
Good point about the stabilizer! It is a must. even if you are just replacing shocks.
Old Sep 24, 2009 | 04:35 PM
Frank4's Avatar
I am I going to have any problems with ACE after the install?
Old Sep 24, 2009 | 04:59 PM
humroot's Avatar
I have ACE and the HD OME setup. Have had it for over a year with no issues at all. The only thing that bothers me is the tracking. It's difficult to keep the truck going straight and when taking turns you have to help it to center with the HD OME lift. I know the TruTracs will fix this issue, but it's more expensive than the lift was.
Old Sep 24, 2009 | 05:30 PM
Frank4's Avatar
Ok, so is this a phenomenon characteristic of OME or is this something that will happen with any lift?
Old Sep 24, 2009 | 10:57 PM
aiden's Avatar
mike, what one do you think is better on out of the one's in the quote? is it meaning like heavy duty as in wight or heavy duty as in i'm where i'm driveing where i shouldn't be and i love it?
dose the truck act odd after lifting? like dose it roll more, or drive funny? some one said something about ace... what is that? and is it on a 96? i'm looking at lifting mine in about 3 or 4 months when ever i get the money for it and it would be nice to know
thanks
Old Sep 25, 2009 | 10:02 AM
I have a 3" lift with ACE, doesn't effect the system at all. By the way, when was the last time you serviced your ACE?
Will you be adding 1 or 2 metal bumpers and or a winch, if not, the Medium duty OME along with the HD OME shock is a great way to go.
Not alot of lift, lots more control on and off the roads and a far better ride then what you currently have.
Bostonc16
Mar 7, 2015 10:32 AM
calebbo
Oct 12, 2011 09:54 PM
Fireman
Oct 25, 2010 07:00 PM
lipadj46
Nov 25, 2009 04:56 PM
