What are the effect of a non-working crank sensor?
Old Nov 27, 2008 | 09:19 AM
stupid's Avatar
Default RE: What are the effect of a non-working crank sensor?
i am replacing my crank sensor.mike said when the crank sensor goes out it will not start.but my rover will start when it sat for a while and then it will die after awhile.i would have to let it sit for another while longer to get it to start again.is this also a crank sensor problem? can you explain how all of this works.does it have something to do with the fuel injectors or what.
Old Nov 27, 2008 | 09:51 AM
What year and mileage on your truck?
Old Nov 27, 2008 | 12:25 PM
stupid's Avatar
its 2003 and has 90 thousand miles
Old Nov 27, 2008 | 01:22 PM
If the crank sensor fails, it will not throw a signal to the ECU indicating the engine is turning over so the ECU won't trigger the injectors.
John Frederick
Mar 26, 2014 02:52 PM
ellebarto
Sights N Sounds
Jan 16, 2013 04:34 AM
DiscoveryHouston
Dec 14, 2012 09:32 AM
jdelp
Mar 20, 2008 11:14 AM
