What else?
Old Aug 25, 2015 | 06:11 PM
DiscoTanB's Avatar
From: Charles Town, WV, originally from Central Valley, California
Default What else?
Got the water issue fixed and on to the 130k service. I have two questions for the group:
1) Should I change the oxygen sensors while replacing the plug wires? and
2) How do I reset the 'Service Engine Soon' light without a scanner?
Working on an '03 Disco II SE with 128k.
As always, any help is greatly appreciated.
Old Aug 25, 2015 | 06:26 PM
lordmorpheus's Avatar
Why is the light on? Have you checked the codes to see what triggered it? After you have fixed the error that caused the light to go on, it will extinguish by itself within a certain number of predetermined drive cycles.
As far as the O2 sensors...it won't hurt as long as you go with OEM Bosch sensors. Other brands and universal sensors cause too many problems. I changed out my front sensors around 100k because I figured they were probably switching slower than new ones. Gas mileage might have improved slightly after that, but no conclusive numbers,
Old Aug 25, 2015 | 06:39 PM
Joemamma1954's Avatar
Dude, if you lived nearby I would hook my scanner, read your codes and reset if you liked. As far as the 02 sensors, I just now changed my upstream at 112000 miles, only because the voltage would stay at the same voltage for up to 5 minutes at a time. I read they should fluctuate, but they weren't. I know some auto parts houses will read codes for free, but don't know about resetting.
Old Aug 25, 2015 | 06:51 PM
R0VERGUY's Avatar
To try and answer your original question. You can try to disconnect the battery over night, that might reset your trouble codes. I think that you should get the codes read before resetting them though like the others have mentioned. Go up to autozone and have the codes read. They won't clear them for you though.
If you are trying to clear the codes to pass an inspection chances are it won't work. They will hook up a scanner and it will say "system not ready" and tell you to come back after the computer has cycled and had time to detect any faults.
Old Aug 25, 2015 | 06:53 PM
R0VERGUY's Avatar
Do you by chance have a Nanocom or scanner that can bleed the ABS modulator?
Old Aug 25, 2015 | 07:01 PM
june82000's Avatar
Most auto parts stores will read the codes for free, however the one light you are talking about may be triggered by mileage as many cars are. You should be able to do a search for that.
Old Aug 25, 2015 | 07:23 PM
Not that I have ever seen or rear about on a NAS D2.
Old Aug 26, 2015 | 06:57 AM
DiscoTanB's Avatar
Alright Gents, thanks for the replies. No, I don't have a scanner but was thinking of getting one. Once I know the codes where do I find out what they refer to? So, as electrically oriented as Rovers are, they don't have a service reminder light like Honda, Toyota, etc.? Seems weak.
Old Aug 26, 2015 | 07:59 AM
Alex_M's Avatar
Just Google them, they should pop up in the top few results.
To be honest, they're not that electronically advanced. It's just a 60's buick with 90s electronics. Excuse me, 90s British electronics.
Old Aug 26, 2015 | 12:27 PM
Yep. Just google "Rover discovery P0xx" (fill in missing digits) and most likely the top several results will link to a post on this forum.
steq184
Freelander
May 14, 2008 03:54 PM
djkiddanger
Apr 8, 2008 05:21 PM
BYURover
Jul 18, 2007 09:00 AM
russ00001
Apr 26, 2006 03:51 AM
silence
Aug 20, 2005 10:54 AM
