What Fuel to run in 97 Disco?
Old Aug 20, 2007 | 11:37 PM
97LANDISCOVERY's Avatar
Default What Fuel to run in 97 Disco?
In the owners manual for my 1997 Discovery it says Premium Gas. What is everyone running? Should I run 89 or 93? or even 87?
Just a quick question. Thanks!
Old Aug 20, 2007 | 11:55 PM
dow's Avatar
dow
Default RE: What Fuel to run in 97 Disco?
premium, only premium... the engine is designed to to run high octane gas, doing anything else can result in hundreds of dollars worth of repairs to your exhaust system, sensors, and fuel system
Old Aug 20, 2007 | 11:58 PM
johnnybob06's Avatar
Always, Always Always run Premium..
These engines were made to run only on Premium and if you don't, you will run into alot of trouble..
Carbon in your engine, rough run, decreased MPG and could eventually damage the engine and we don't want that now do we.. :]
Happy Rovering!
John-Robert
Old Aug 21, 2007 | 12:01 AM
Thanks for the quick info!
so, 93 octane fuel?
Old Aug 21, 2007 | 12:05 AM
...you got it!
Old Aug 21, 2007 | 12:10 AM
ScottJ's Avatar
Do they really call for 93 or is it just 91?
Oddly enough my wife's A4 calls for 91 minimum and we can sometimes find that a bit cheaper than 93.
Old Aug 21, 2007 | 12:15 AM
Well, yes 91 is much better than 87, but you can feel a slight difference in ride when you change from 91 to 93...
and honestly, the money diference is only a couple dollars total when using 93 octane rather than 91 :]
just my two cents..
John-Robert
Old Aug 21, 2007 | 08:39 AM
The higher the octane, the better the performance and MPG. The lower the octane the less mileage and the more carbon build up in the engine.
Old Aug 21, 2007 | 11:17 PM
awesome! thanks!
**One more quick question, what kind of oil is suggested for a 1997 Discovery?
Old Aug 21, 2007 | 11:28 PM
Synthetic!
Mobil 1 makes a really good Synthetic oil... that's what I use, along with the Mobil 1 oil filter... :]
