What happens when you swamp the floor in a D2
Old Apr 21, 2009 | 09:36 AM
tornado_735's Avatar
A $6 repair? That's what I'm talking about!
Old Apr 21, 2009 | 09:14 PM
andy's Avatar
[QUOTE=tornado_735;112618]A $6 repair? That's what I'm talking about![/QUOTE
That is a big time luck out, they still had the D2 your driveshaft came out of and they were having a half off sale that day.
Now I have saturated the carpets with cleaners and left the sill plates off with blocks holding the carpets up, hopefully it decides to dry out nicely.
Old Apr 22, 2009 | 02:11 AM
rrhyne's Avatar
Here's a thread I saved from DWeb. Covers LOTs of stuff to check, how to dry, mold etc.
http://discoweb.org/forums/showthread.php?t=15250
Old Apr 22, 2009 | 07:49 PM
[QUOTE=andy;112695]
Speaking of which,
Dude, again...
Thanks a Million. Runs like a raped ape now that I fixed the misfire!
Old Apr 22, 2009 | 09:13 PM
andy's Avatar
Well there appears to be at least one bright spot on the horizon, I just went for a cruise and for the first time since I bought the truck it didn't smell like stale cig smoke. Just a cocktale of upholstry cleaner, carpet shampoo, and air fresheners
Old Apr 22, 2009 | 10:17 PM
geotrash's Avatar
Default Drain the diffs
Might want to drain out the differentials and start with fresh gear lube.
Old Apr 23, 2009 | 02:33 AM
Urban Panzer's Avatar
Originally Posted by discoxd
you should have just gone faster... havent you ever watched the camel trophy videos? momentum is key... hit that hole floored in like second doin like 35 and you skim halfway across...
Not really good advice tbh................Hitting ANY water to fast is not a good idea as you just dont know how deep it is or whats lying in there......
The camel trophy drivers didnt OWN their vehicles, if they busted it they would just be given another one........
First rule in offroad driving, AS SLOW AS POSSIBLE, AS FAST AS NECESSARY
Old Apr 23, 2009 | 04:04 PM
With the tires that are on Andy's truck there was not much he could have done.
If you have a good A/T or a M/T tire once you start to loose forward momentum if you start to rock the steering wheel from side to side really fast the sides of your tires will bite into the ground and you can keep moving in most cases, but if you high center like he did then you are done.
If you cant get enough traction to drag your frame and axles through the quagmire then you are dead in the water, this is when you need a winch.
And Panzer is right, think of how you treat a rental car, that is how those Camel Trophy guys treat their trucks.
Old Feb 23, 2018 | 10:43 AM
Meldav32's Avatar
Andy~ Do you still own this same Rover?
Old Feb 24, 2018 | 09:32 AM
Alex_M's Avatar
The last time Andy was online was 2010.
