Working Theory
Jet-Air Electromagnetic cold intake add-ons were developed to dramatically reduce air intake restriction, allowing more air flow to your engine, and to create a perfect spiral airflow shape. Having more and regulated airflow contributes to more usable output and pep throughout the entire RPM range. The Jet-Air concept was designed to improve low-range and mid-range output, mid-range torque and economy on internal combustion engines. In addition to adding salient more performance level, the standalone Jet-Air instantly improves the engine fuel efficiency. Your Land Rover Discovery 4.0L performance air intake kit includes a chip designed to control the electromagnetic fluctuation using the signals of the Intake Air Temperature sensor. As a result, air flow will be permanently regulated according to the actual varying Cubic Feet Per Minute for the proper air motion vector, and because of the perfect combustion, result in peak output and magnificent fuel efficiency. This controller chip taps into the Intake Air Temperature sensor's signal wire. Jet-Air Electromagnetic air intake add-ons are specifically designed to take full advantage of today's vehicle technologies. It speeds up the incoming air charge in the air intake. This in return gives you tremendous combustion efficiency. The cross-link polyethylene air duct is designed to a specific design. It insulates and protects the air mass from pulling hot air from the engine compartment, thus, increasing pony. The duct is sculpted to give the engine a less restrictive air pass to breathe. Land Rover Discovery 4.0L Jet-Air Electromagnetic air intake gives you maximum horsepower and perfect throttle response, by reducing air restriction and boosting engine pony. The special spiral shaped internal geometry optimizes and speed up the airflow throughout the intake system. High Performance bellows provide flexibility while they still maintain strength and thermal stability.
I bought a bunch of Loony tunes DVD's for my kids many years ago. The ringtone for a text message from my son ( now 17 and driving my D2) is:
" where is the kaboom? there was supposed to be an earth shattering kaboom!"
